05-08-2018, 07:38 PM | #1 |
Drives: 11 camaro Join Date: Mar 2017
Milled heads question
As the story goes I bought a set of tsp lsa heads that were ported,milled 5 thousandths, with hollow stem valves,68cc. Called TSP and l learned today that they were actually milled 20 thousandths and 67cc. I want to put them on my sbe ls3. What will be needed to make them work? Thicker head gasket? Shorter pushrod? Any input is welcome in advance! Thanks
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
05-08-2018, 09:02 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
slap on a set of LS9 gaskets...then yes measure for your new P/R length...good luck!
peace...
05-09-2018, 08:04 AM | #3 | |
Drives: 2014 Chevy SS Join Date: Nov 2014
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
05-09-2018, 08:58 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Measure PTV (clay or dial indicator method). You'll need a spare lifter set up as a solid. And some spare headgaskets/headbolts to mock up the heads as installed.
Measure PR length. Select the PR length based on the lifter plunger depth specified by the lifter maker. Usually about .070" ish for regular travel lifters, .030"ish for short travel. When mixing and matching modded parts, only way to fly is measuring and perfecting. Some good youtube videos out there showing the processes. |
05-09-2018, 09:18 PM | #5 |
In for the learning curve
Car mods: never enough!
