06-30-2015, 04:17 PM | #1 |
SS
onstar can't communicate with my car and mirror dead
Not sure if its a good or a bad thing lol
My link did a couple of fade outs in daylight driving also not sure if street mud in Deadwood SD. caused light sensor to dim it or not?, 12.4 volts to 12.6 on driver information screen, I read this as a normal condition , Any advice out there?
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
06-30-2015, 07:32 PM | #2 |
Drives: 2012 2SS Join Date: Jan 2015
Check the fuses? There's a fuse just for the onstar.
06-30-2015, 10:29 PM | #3 |
Drives: 2014 2SS/RS CRT Join Date: Apr 2014
Happened to me before. I disconnected the battery (for something different) then plugged it back in about an hour later. The mirror came back to life and Onstar stopped complaining.
Well, I didn't renew Onstar so it's still complaining.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake --Solo HFC |
06-30-2015, 10:50 PM | #4 |
SS
thanks will do
