03-25-2018, 11:24 PM | #1 |
Drives: 2015 Camaro LT/RS Join Date: Mar 2018
Exhaust setup check before install
Hello all,
First thank you all for such great posts with some great info on these forums. I am a newbie Camaro owner and want to learn more about the cars in general to be able to slowly upgrade the models as my appetite grows. I recently acquired a 2015 1LT v6, which i though was a great entry model into the Chevy sports cars. Her name is Carmen and inspired by all of your ideas she is getting the exhaust system rebuilt in a few days, but i figured i'd ask your opinion if you think the planned setup works Only the items in picture would be used with secondary cat and rest of stuff deleted. |
03-26-2018, 06:07 AM | #2 |
Drives: 2012 Camaro Ls Join Date: Nov 2017
Welcome, so I take it that when you say exhaust, you mean full catback right? If going that route you might want to get an intake, there are too many to list but for me I went with a cold air induction intake, solo high flow cats & catback exhaust as well, all that's left now is to get her a TB & tuned and she is good to go.
Remember, your engine is a big air box, the better it breathes the more power & torque you can get out of it. With the LXF engine to my knowledge you cant mod them like you could the previous engines. Some of the other members on here will chime in and point you in the right direction as well. Hope this helps and keep us posted |
03-26-2018, 07:33 AM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
The exhaust set up you propose in the first post is perfect, though I'd recommend the MRT v2 instead of the v1 based on other posters' responses.
03-26-2018, 01:37 PM | #4 | |
03-26-2018, 01:43 PM | #5 |
Thank you, I decided to go with version 1 because i liked personally more how they sounded, from my understanding both versions are good options for a smaller V6 engine builds. I will post the results of sound and performance sometime next week.
03-26-2018, 01:55 PM | #6 |
Drives: 2015 AGM 1LT Join Date: Jul 2015
That setup will sound good. Its similar to my current one except I have catless downpipes. They make the car much louder, but also more raspy and rough.
The scoop and WW install should be pretty easy as long as you have some basic hand tools. I did need to use a dremel on mine. So beware about that. Let me know if you need any help.
Performance: Overkill Supercharger, VMAX ported throttle body, JacFab Intake and Spacer, VTC Throttle Controller, ARH Catless Downpipes, Magnaflow Res-X, Stock Resonator Delete, MRT V1 Axle Back, Solo J-Pipes, E85 flex fuel, MRR 228 20x10 and 20x11 wrapped in MPSS,
Cosmetic: 15% Tint on side Windows 5% on back, LED fogs, SS bumper conversion, de-badged, Z28 front grill, Eagle Eye headlights, HID conversion, VIS terminator hood, Red LED sidemarkers with 5% tint. |
03-26-2018, 06:03 PM | #7 |
You'll love it either way. And like Pyro said, the intake and air scoop are easy installs. If you don't have a dremel, you might be able to get a pair of clippers or shears up to trim the plastic behind around the radiator. But certainly not difficult.
03-26-2018, 06:33 PM | #8 |
A hot box blade/knife will also work in a pinch I'd imagine.
03-26-2018, 10:56 PM | #9 | |
I did see that a lot of people went with ARH High Flow CAT downpipes, which is something I am looking forward in the future, simply because from my understanding the stock newer car CATs are pretty well flowing already so figured not much of a change. Please advice if I am wrong. You also mentioned basic tools, i have like screwdrivers and pliers, but what would be a good tool starter kit I could get for working on my car on a newbie level? Thank you! |
03-26-2018, 11:22 PM | #10 | |
03-26-2018, 11:55 PM | #11 | |
Hawaii at least don't do emissions test like California. Its okay i wouldnt be suprised 2025 version of Camaro will be fully electric and lamo probls lol <3 |
03-27-2018, 01:38 AM | #12 | |
03-27-2018, 08:57 PM | #13 |
Just finished the installation this morning of entire setup as listed at first post. We cut the pipes right at o2 sensor and new setup all the way back. Drove street and highway and it is OMFG good. Raspiness doesnt exist at all, its very deep to the point of my seat vibrating to the engine like as if I had a set of deep sounding subwoofers below my car. My favorite part was that engine while idle no longer sounds like a dodge neon high pitched sound which was stock sound before this.
Sound from inside and outside is literally amazing i cannot wait to upload a couple of youtube sound clips. Also i know people talked on forums about drone sounds and i honestly dont hear anything like that at all. Every time i touch accelerator slow or high speed it is responsive immediate low pleasure to the ears. Another favorite of mine is the moments between shifts are so obvious now too... in love with this basically as you can see lol. Performance wise im sure with bigger and straighter pipes the resistance is well reduced, ill let the dyno speak for all boltons eventually when im ready to do such step now its time to install the Robo-fab with schoop/ww kit, which ill be doing friday and pretty excited to do on my own. Thanks again for tips all <3 |
03-28-2018, 01:31 AM | #14 |
Glad everything went well for you, cant wait to see your videos, the intake will probably make your ride sound a little bit deeper. keep us posted.
