09-14-2015, 03:01 PM | #1 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
ZL1 based on 2016 performance numbers
Looking for guesses on what the new? ZL1 Performance numbers will be based on the released SS numbers 4.0 60 and 12.3 1/4 mile. We could start with the estimate the ZL1 will get the LT4 at about 640 hp.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
09-14-2015, 03:16 PM | #2 |
Drives: 2013 ZL1 Join Date: Jan 2015
I would say the current zl1 with 640 crank hp -.2 second for the weight. Probably a 11.6 @ 123-124. It will certainly be a bit slower than the current Z06.
2013 A6 ZL1
09-14-2015, 03:54 PM | #3 |
Drives: 2018 ZL1 1LE, 1969 Nova SS 396 Join Date: Aug 2014
I would predict 0-60 3.4 seconds and 11.5 @128. Cant wait to see the numbers.
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook| |
09-14-2015, 05:32 PM | #4 |
While that would be cool, I don't see it. Standard SS is around 3700lbs depending on options, add at least 150 lbs for the blower, bigger brakes, heavier duty drivetrain, additional coolers, etc and you might be 150-200 pounds lighter than the C5 ZL1. 640 crank hp often yields 121-122 trap speeds at 4000lbs.
2013 A6 ZL1
09-14-2015, 07:10 PM | #5 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I think 11.5-11.6 is reasonable performance to expect from a new Z. Our car weighs 4,120 so that puts the new car at 3,900-lbs assuming it indeed weighs at least 200-lbs less. Still a fat pig, but lighter than ours and with 60 more hp. Also consider the aggressive gearing of the A8 will help a lot.
09-14-2015, 07:32 PM | #6 | |
Heck, when the C5 Z came out a guy ran an 11.4 with a really good DA. But 128mph with just 60 more crank hp and -200lbs? We shall see.
2013 A6 ZL1
09-14-2015, 07:34 PM | #7 |
GuitarmageddonZL1
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado Join Date: Feb 2015
I'm thinking (if they even make a ZL1) it will have more hp and tq than the new CTS-V, just like the current ZL1 does. I wouldn't be surprised to see about 650-660hp.
09-14-2015, 07:37 PM | #8 |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Not that it makes a big difference, but I've read that the 2017 Z06 will have an increase in power numbers from the current 650 HP/650 TQ and if so, figure the '17 ZL1 will be at the 650 mark as it has already been announced that the Caddy V will have 640. This will keep the GM power food chain intact.
09-14-2015, 11:00 PM | #9 |
Drives: ZL1 Gone but not Forgotten! Join Date: Mar 2015
Who cares!! I got over 700 to the crank.
So whatever it is it won't be impressing me unless I see hellcat beating numbers. (Which isn't going to happen) Sent from my SM-N910V using Tapatalk |
09-15-2015, 12:48 PM | #10 |
me 2......but still it's good to see the ZL1 get a much needed power boost for the Gen6 and with the weight reduction, it doesn't need to get to the Hellcat power numbers in order to hang with it.
09-15-2015, 02:37 PM | #11 |
Drives: GM Join Date: Sep 2010
Nuff said :
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
09-15-2015, 02:56 PM | #12 | |
Ted.
www.jannettyracing.com
09-15-2015, 03:06 PM | #13 |
HAMMER PILOT
I wasn't thinking 2016, probably 17 or 18. Just trying to get some inputs based on the weight and performance of the new SS.
09-15-2015, 03:09 PM | #14 | |
Ted if I wait in a 5th gen ZL1 how much power can I make without a tune? Will those Bigflow headers fit a 2014+ ZL1 without trimming the under body aero? What kind ET can I expect in a manual ZL1 with Drs? I am thinking it is good to keep the warranty in a ZL1. |
