Old 03-06-2018, 09:51 PM   #1
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man
Carlyle 15 inch kit Probs
This is ridiculous. Wheel is touching in 4 or 5 places by 1/16-1/8. I was able to grind back everything including brake line bracket. The last thing is the calipers. They are touching by 3/16 and don't want to grind that much. Anybody else run into this with racestar 15" wheels?
ZL1C7 is offline   Reply With Quote
Old 03-07-2018, 08:01 AM   #2
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
I just installed the kit with some 15" Weld wheels. Some stuff was rubbing a little bit with the car jacked up and the suspension just hanging there.
When the car was lowered down and the weight put on the wheels, everything cleared fine.
I also ground the brake line bracket for more clearance, and touched it up with black paint.
stratman2SSRS is offline   Reply With Quote
Old 03-07-2018, 03:33 PM   #3
ZL1C7
ZL1C7's Avatar
Thanks for the info...The difference must be the wheel
Old 03-08-2018, 07:55 PM   #4
PFL
PFL's Avatar
Drives: Camaro SS
I was disappointed with the 15 "carlyle kit. This kit is definitely not a real 15" conversion, it only accepts weld wheels with 5gen camaro specification. it does not clean other wheels. we have to get stuck only on wheels for 5gen
PFL is offline   Reply With Quote
Old 03-08-2018, 10:30 PM   #5
1709
9.56@144.09
Drives: 2013 zl1 black
what I had to do is add a 3/16 spacer and longer wheel studs, and works fine now
1709 is offline   Reply With Quote
Old 03-09-2018, 02:53 AM   #6
ZL1C7
ZL1C7's Avatar
Funny, I just put the .500 longer ARP studs in and ordered 3/16 spacers
Old 03-09-2018, 05:05 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
Glad i glanced over here....
bayarea408 is offline   Reply With Quote
Old 03-16-2018, 01:14 PM   #8
ozzy1le
ozzy1le's Avatar
Drives: 2015 camaro 1le
Any updates or pics completed
ozzy1le is offline   Reply With Quote
Old 03-19-2018, 08:48 PM   #9
se7en
Drives: 10 Procharged SS
What is the part number for these ARP studs, please. Been searching for them.
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
se7en is offline   Reply With Quote
Old 03-20-2018, 02:06 PM   #10
stratman2SSRS
ARP studs part # 100-7703
I bought some 1/2" Monster Lug nuts for my street tires, and they look pretty good.
Old 03-20-2018, 10:41 PM   #11
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
This makes me glad I built my own kit
I used their brakes and you can't put wheel weights on the inside of the wheels because the caliper hits them.
I had to beed balance them.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-21-2018, 08:17 AM   #12
HOU_TX_SS
Drives: Camaro SS
What components did you use to do the conversion?
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
HOU_TX_SS is offline   Reply With Quote
Old 03-21-2018, 12:33 PM   #13
ozzy1le
ozzy1le's Avatar
I would love to hear how u did it 2010 camaro
Old 03-21-2018, 03:58 PM   #14
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
2010_camaro, I'm interested as well. I need to get my 15 inch setup done.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
