07-14-2017, 05:59 PM | #1 |
Drives: 2012 Camaro 1LS Join Date: Apr 2008
a la carte magnaflow?
Hi all,
I was wondering if its possible instead of ordering complete exhaust systems from Magnaflow if i can just order the mufflers? I am particularly interested in finding out what the 15167 Magnaflow mufflers would cost. |
07-14-2017, 06:17 PM | #2 |
Drives: 2011 RS Join Date: Apr 2011
Their website says part #15354 is an axle-back that will fit your car. It's between $775 and $825 on EBAY and AMAZON.
07-14-2017, 09:35 PM | #3 |
Drives: 2011 Camaro 2LT/RS Join Date: Jan 2017
Yes you can order the mufflers separately. I ordered the resonated X-pipe 11386 and a pair of their 4x9x14 center/center mufflers 11216. I was fortunate to get them on sale and only spent a total of $215. I'm hoping to get it all installed next week
07-15-2017, 09:12 AM | #4 |
Are you ordering directly from Magnaflow? Eddie, I just want the mufflers off the 15167 kit. The 15354 kit you directed looks like a separate kit.
I cant find the part numbers for just the mufflers for the 15167 kit. |
07-15-2017, 09:18 AM | #5 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Have you asked Magmaflow yet?
07-15-2017, 11:52 AM | #6 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you search for the 15167 kit and then go to specs you'll see the muffler sizes - lucky for you I took it upon myself to find out for you Looks like 12225 or 14225, depending on whether you want satin or polished finish.
07-15-2017, 01:25 PM | #7 |
Drives: 2012 2LT RS White Born: 11/10/11 Join Date: Nov 2011
The shop I used deals with Magnaflow so they had them in stock (11235) along with other sizes and types. The 11235 has each outlet on opposite ends. The 12225 has one outlet in the middle and the other on an end. It's just whatever you want to use. Both work the same.
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A |
