09-09-2011, 09:36 PM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Aug 2011
JRE "Rough Idle Blower Cam"
Guys, I bought this cam and had it sent to Livernois and installed in my 419 stroker. I've since installed the engine and have driven the car about 200 miles.
While the idle sound of the engine is nice, it doesn't feel as strong as my LS3 did, which had a different blower cam. It was street tuned, so I have not had it on the dyno yet to see the actual numbers. But the LS3 put down 641rwhp and 548rwt; this 419 feels like it's about 600rwhp. The 419 has 9.7:1 compression and the JRE cam and my Whipple blower has the same pulley; the tune is similar in terms of timing aggressiveness and A/F ratios. Looking at the spec car on the JRE cam I see it has something like 224/236 duration but only a 114 LSA. My LS3 blower cam had similar durations, but a 117 LSA. So, I'm wondering if the narrower LSA on the JRE cam is reducing the effectiveness of my blower. Thoughts? |
09-09-2011, 10:11 PM | #2 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Sounds like you are lacking a good dyno tune.
09-09-2011, 10:34 PM | #3 |
Adding cubes to a blown vehicle doesn't always result in more power, just more efficient. You added cubes but lost compression and your tune is for another motor. Being a bigger motor with lower compression its time to turn up the boost some and get a new dyno tune. The LSA change in the cam will just raise your power band level. So you'll be spinning the motor a little higher to reach peak numbers.
09-10-2011, 01:30 AM | #4 |
You had X amount of boost pushing into 376 inches.
Now you have x amount of boost pushing into 418 inches. Also you are about a point down on compression, which you should be on a FI motor. Just spin the whipple a little faster, which will return your boost preasure. Retune. I`m confident JRE`s cam is great. |
09-10-2011, 03:15 AM | #5 | |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
09-10-2011, 08:09 AM | #6 | |
You Also NEED an Entirely Different TIMING MAP. A stock compression 376 will feel a whole lot stronger than a 9.7:1 416 all day long. The Idea of lower compression is so you can replace it with BOOST on pump gas. You are welcome to call me to discuss your build and what to expect. Ted.
www.jannettyracing.com
09-10-2011, 08:23 AM | #7 | |
Drives: 2010 Camaro Join Date: Jun 2009
What everyone is saying in this thread is correct about being more efficient and needing to pulley down.
Thank you, Rick |
09-10-2011, 08:24 AM | #8 |
I Wanna Go Faster!!
09-10-2011, 08:36 AM | #9 |
Well I think this problem is solved. Now lets go grab some beers and pat ourselves on the back.
09-10-2011, 11:14 AM | #10 | |
I'd love to talk to you Ted, but the only time I get to "play" with this stuff is when your shop is closed. As for the dyno tune; earlier this year I decided to start tuning myself after dropping close to $5K in dyno tunes the year prior. $700 for HP Tuners and a wide band, $500 for a Tuning School material and lots of reading! So, I'm using my butt dyno! |
09-10-2011, 11:17 AM | #11 | |
And a bunch more timing in the OFF Boost Regions of the timing Map.
Similar Threads | ||||
JRE ROUGH IDLE BLOWER CAM AND KB RESULTS | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 08-26-2013 08:14 AM |
JRE LS3 Rough Idle Hot Street Blower Cam Package | ITGuy11 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 07-15-2011 12:22 PM |
JRE Rough Idle Blower Cam | StreetStrip | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 06-09-2011 07:10 AM |
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain | robertway | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 02-21-2011 09:38 PM |
JRE blower cams | S-eatin-grin | Forced Induction - V8 | 11 | 02-11-2011 06:28 AM |
