Old 08-01-2012, 04:21 PM   #1
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
ZL1 Fuel Pump with BAP
I've tried searching, but can't find a definitive answer. Will a ZL1 pump with a MSD BAP, along with ID850 injectors support 650RWHP?
I know the preferred setup is the LPE twin pump, but I am trying to see if the ZL1 pump that I already installed was a waste of time and money...
ITGuy11 is offline   Reply With Quote
Old 08-01-2012, 06:03 PM   #2
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
I have this setup and the answer is yes.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 08-01-2012, 07:00 PM   #3
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Yes it will, easily. But if your going to go for much more you will need a twin set up. Nice choice of injectors.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 08-01-2012, 07:39 PM   #4
ITGuy11
Burning up tires
How close are you to maxing out the zl1 pump, and what are your power numbers?
Old 08-01-2012, 08:11 PM   #5
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Yeah I also think you will be fine the LPE twin pump is a better choice, but I think the ZL-1 pump is under estimated. I continue reading about modifided ZL-1 Camaros using the stock pump and pushing it over 650 rwhp. Check out August issue of GM High-Tech where Redline Motorsports pushed their ZL-1 Camaro to 654 rwhp and 624 rwtq with the stock pump and it ran a 10.34 at 134. They even bumped up the boost on race gas and got 730 rwhp to run a 10.23 at 138.94
I will be installing the ZL-1 fuel pump with the MSD BAP that I already have when I get my cam installed. hope to be at 650 rwhp. Good Luck with your build.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 08-01-2012, 08:46 PM   #6
Supermaro585HP
Drives: 2011 Camaro SS RS
I have the Edelbrock supercharger and I just got the ZL1 pump 60 pound injectors and 3" pulley and along with everything eles I have should be pushing around 650 RWHP and everyone I have talked to about the ZL1 pump says that it is good for at least 650 to 700 RWHP. You will be fine man. I'm getting everything installed next week and will get the exact numbers.
Supermaro585HP is offline   Reply With Quote
Old 08-01-2012, 09:08 PM   #7
walhan_qtr
..[ Z06-QTR ]..
walhan_qtr's Avatar
Drives: '10 Camaro 2SS RS M6/ 07 C6 Z06
Send a message via MSN to walhan_qtr Send a message via Yahoo to walhan_qtr Send a message via Skype™ to walhan_qtr
one guy here made 625whp with no bap. so I say you will be fine with boost a pump at 650whp. but I am interested in knowing this too!
- 07 Silver C6 Z06, Darton sleeved LS7, 441ci, H/C/I, Duel Stage Nitrous, RPS BC3, TR6060, E85. (615whp/582wtq N/A)
- 09 Blk Z06, 427ci LSX, F2 Procharger, Brodix, Holley, ZR1 TR6060, ... (1204whp/1045wtq @ 24psi)
- 06 Blk C6, Darton Sleeved LS2, 427ci, H/C/I, F1X, RPM Trans/Diff, RPS BC3. (New #s soon)
- 10 Black Camaro LS3, 2SS/RS, H/C/I, bolt-ons, Spec. (470whp/450wtq).
- 07 Black Corvette C6(SOLD).
- 98 White/Red Corvette C5(SOLD).
walhan_qtr is offline   Reply With Quote
Old 08-01-2012, 10:32 PM   #8
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
I love your videos.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 08-01-2012, 10:55 PM   #9
Cpanthers85
Drives: 2011 Camaro 2SS RS
Be sure to post your results!!! I'm curious if those 60# injectors will be enough. Seems that everyone reccommends the ID85, but everything I read says that the 60# is plenty
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 08-02-2012, 09:00 AM   #10
BLACK10
BLACK10's Avatar
im putting down 720rwhp with the ZL1 pump and a bap. Also running meth though
Old 08-02-2012, 09:35 AM   #11
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
With a ZL1 Fuel Pump and ID850's you will be fine for 650rwhp. No BAP needed. Should only be around 58%IDC as well.
Chris
Chris-HPS is offline   Reply With Quote
Old 08-02-2012, 10:53 AM   #12
fourmz
Fourmz
fourmz's Avatar
As far as how close I am to maxing out the pump... I have no idea. Ted assured me that this is a safe setup and after 2800 miles of "Very spirited driving" I have had no issues.(I do add Torco to my fuel). Dynos are hard to come by in Alaska but my projected numbers should be around 650 RWHP.
Old 08-02-2012, 10:59 AM   #13
MANNYS2SS/RS
Fourmz what setting do you have the BAP at with the Zl-1 pump?
Old 08-04-2012, 05:46 AM   #14
2010SSRSM6
2010SSRSM6's Avatar
Chris
+1
The ZL1 pump is impressive.
