Old 03-27-2017, 10:16 PM   #1
2013blackgt
2013blackgt's Avatar
Drives: Katech Stage 2 2015 Z/28
Mobil 1 0w40
I was thinking about using mobil 1 0w40 euro since I have a couple of jugs in the garage. I think if its good for my bmw then it should be good for the Z. What's your thoughts?
Katech Stage 2 SN #9
2015 Camaro Z/28 Red and Black #1193
2013blackgt is offline   Reply With Quote
Old 03-27-2017, 10:20 PM   #2
aris
Drives: Z/28
Why? I wouldn't do that.
Run the correct weight. I don't think that stuff is heavy enough.
aris is offline   Reply With Quote
Old 03-27-2017, 10:43 PM   #3
markstoys
Drives: 2015 Z28 #141
I used 0W-40 for my when I first got my car. The viscosity was right between the 5W-30 recommended for the street and the 15W-50 for the track, so I thought it was a good compromise and would cut down on oil changes. It also has about the same zinc/phosphorous as the 15W-50. Mobil has recently changed the formulation on the 0W-40, reducing the viscosity to very nearly the same as the 5W-30, it still has a lot of zinc/phosphorous in it however. I'm not sure what the warranty implications are, but since the 0W-40 is not really any thicker than the 5W-30, I just run the recommended viscosities for the street and track. It's a bit of work to change the oil so often, but what are you going to do?
markstoys is offline   Reply With Quote
Old 03-27-2017, 10:55 PM   #4
2013blackgt
I was going to do both. I was thinking it would be a good compromise between the 5w30 and the 15w50, like you said.
Old 03-27-2017, 11:06 PM   #5
Og Neon
Drives: 2008 Evo X, 2014 Z/28
0w-40 is actually a good oil to use. It has more zinc then the 5w-30 and the ideal viscosity for cold starts. It is really a perfect balance and I use to run that on my track Evo.
Og Neon is offline   Reply With Quote
Old 03-28-2017, 03:23 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The Hellcat uses 0W-30.
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Old 03-28-2017, 05:32 PM   #7
Shoupaloop
Drives: 2015 Z28
I used 0-40 in my SRT. I have thought about using it during the summer as a street and track hybrid. It's thinner at start up vs 5-30, and a little heavier at full temp. It seems to me like this would be ideal.
Shoupaloop is offline   Reply With Quote
Old 03-28-2017, 09:49 PM   #8
Og Neon
Yup, I also run 0w-40 in my JC SRT.
Old 03-28-2017, 10:58 PM   #9
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
This^. I used it in my Z06 (LS7) for a few years. Good oil.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
