05-13-2017, 09:57 AM | #1 |
BEASST
Drives: Murderd convertible Join Date: Aug 2016
Cant go in reverse/ Stuck in park
Did a little burn out leaving work drove home perfectly fine ...Now this morning its stuck in park and wont go in reverse... I disconnected the negitive battery cable no luck.. Can sombody tell me where the reverse solenoid fuse is located ? I have no idea what to do from here thanks guys.. 2011 L99
2011 SS L99
05-13-2017, 10:06 AM | #2 |
Drives: 2013 2ss/rs A6 yellow !!!!! Join Date: Nov 2011
Are you hearing the clicking from the release mechanism when you step on the brake pedal
Sent from my SM-G955U using Tapatalk |
05-13-2017, 11:18 AM | #3 | |
BEASST
Yes i hear the clicking but not from the break pedal..I definatly hear the clicking when i press the button on the shifter to put it in gear but it wont budge
2011 SS L99
05-13-2017, 11:39 AM | #4 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
You are not parked on a hill are you? Could just be jammed by the weight of the car against the parking pawl.
The Bird is the word! |
05-13-2017, 11:52 AM | #5 | |
BEASST
I mean its slightly on a slope but cant be that its even less than your typical driveway slope.. My buddy said to check the fuse for the taillights but i dont have a manual of course can sombody tell me what fuse that would be?
2011 SS L99
05-13-2017, 12:02 PM | #6 |
BEASST
I had my girl check make sure both breaklights are working and they are... Im lost
2011 SS L99
05-13-2017, 12:18 PM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I do not have an automatic. But dont most have a small cover near the shifter that covers a key hole? This can be used to unlock the shifter.
More to come. |
05-13-2017, 12:18 PM | #8 |
Drives: Miss Con Ception Join Date: Aug 2016
Go here to find your manual. https://my.chevrolet.com/learn
There is a manual release in the console if none of the other ideas work.
2011 1SS/RS LS3 CGM
05-13-2017, 07:02 PM | #9 | |
BEASST
Thanks man. Appreciate that. Took the shifter component apart cleaned it up threw a lil wd40 on an eventually got it in reverse, i thought it was just stuck but still took it in to a local shop i always go to and they think its somthing to do with the brake pedal i forget what they said its called but its only $50 i figured it wont hurt.. Part comes in on Tuesday but i was able drive home they said if it happens again to pump on the break pedal to get it out of park... Well see i guess.. Thanks guys
2011 SS L99
