Old 09-30-2018, 05:50 PM   #1
chris'stransam
chris'stransam's Avatar
Drives: 2014 1LE , ZL1-1LE , 1999 WS6
2014 1le ac issue
So my ac stoped . The ac compressor is still working , and the line still gets cold . I checked the high psi switch .I thought it could be the blend door , but it will switch position and blow from diffrent vents when switched . Don't know what to check ? Any one have a y ideas ?
chris'stransam is online now   Reply With Quote
Old 10-21-2018, 11:26 AM   #2
Ryan63052
Drives: 2012 Camaro 2SS
I am having the same problem. Does your heat do the same as well ? Mine also will switch different positions when i switch the vents. I believe its one of the temp actuators on the left and right but not 100%. I am trying to find more information myself.
Ryan63052 is offline   Reply With Quote
Old 10-30-2018, 01:13 AM   #3
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Mine had the same problem, had the dealer replaced the entire AC system. Supposedly, the condenser was clogged!
CreeperRS is offline   Reply With Quote
