Old 04-13-2012, 01:01 PM   #1
1sikRS
Drives: chevy
bleeding brembos
Anyone know how to bleed the brakes on the ss camaro?? looks like the brembos have 2 bleeders. I'm gonna change em out to speed bleeders and stainless lines. just need to know how to bleed em
1sikRS is offline   Reply With Quote
Old 04-13-2012, 01:36 PM   #2
Stealth6
Drives: '17 GT350
Bleed order:
* Right rear inner
* Right rear outer
* Left front inner
* Left front outer
* Left rear inner
* Left rear outer
* Right front inner
* Right front outer
Stealth6 is offline   Reply With Quote
Old 04-13-2012, 03:40 PM   #3
1sikRS
Drives: chevy
Thank u so much
Old 04-13-2012, 03:47 PM   #4
1sikRS
Drives: chevy
Ok so u open on bleed in then shut it then bleed the outer on the same caliper rite??? Sorry for askon silly.questions
Old 04-13-2012, 03:52 PM   #5
iHasCamaro
Drives: Silver 2012 1SS
Don't get any fluid on the calipers. Brake shop bled the ones on my Evo and got it all over them. Instant paint peeling.
iHasCamaro is offline   Reply With Quote
Old 04-13-2012, 04:46 PM   #6
Chito
SoCal HT5
Chito's Avatar
Drives: 2010 Camaro black 2ss/rs
I'm trying to do the same, when your done can you please post pics or do a DIY please. thanks.
Chito is offline   Reply With Quote
Old 04-14-2012, 01:33 AM   #7
Stealth6
Drives: '17 GT350
That is correct....
Old 04-14-2012, 10:29 PM   #8
NavyDood
Retired Navy
NavyDood's Avatar
Drives: 2010 2SS/RS
Originally Posted by Stealth6 View Post
Bleed order:
* Right rear inner
* Right rear outer
* Left front inner
* Left front outer
* Left rear inner
* Left rear outer
* Right front inner
* Right front outer
Is there something special you found in the factory service manual that states which sequence to do the bleeding? I am not referring to the inner and outer bleed screws. This would be the first car I ever heard of not doing the brake caliper that is farthest, second farthest, third farthest and then fourth farthest. IMO the sequence should be RR/LR/RF/LF.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
NavyDood is offline   Reply With Quote
Old 04-14-2012, 10:44 PM   #9
iHasCamaro
It's common to start furthest away from the master cylinder and work closer. I always do it based on the location of the abs distribution block though which is often on the opposite side of the car. I don't know if there is conventional wizdom top to bottom, but I do top first since it seems in, my feeble mind, would get the bubbles on the top out first. Might be wrong about that though.
Old 04-15-2012, 10:09 AM   #10
Stealth6
Drives: '17 GT350
This isn't a "new" procedure for the Brembo system. Look at step #16... Oh, one more thing, the same sequence is listed for Cadilac CTS-V (under the FAQ's).
http://www.southerncarparts.com/corv...ion-ex-45.html
Old 04-15-2012, 01:51 PM   #11
Merc
In The Circle
Merc's Avatar
I bleeded my Brembos in the conventional way when I changed out the brake lines with no ill affects. I try it the right way when I install the the roll control.
Old 04-21-2014, 12:53 PM   #12
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Can someone please let me know if this sequence also applies to the V6?
* Passenger rear
* Driver front
* Driver rear
* Passenger front
Inuyashas_Brother is offline   Reply With Quote
Old 04-22-2014, 09:13 AM   #13
MLL67RSSS
Drives: car
Speed Bleeders have a built in check valve. No need to do the open-close, open-close routine. You crack them open and pump the brakes until there are no bubbles in the drain tube and then you simply reclose/tighten them. Makes it SOOOOOO much easier!!!!!!!
http://www.speedbleeder.com/
MLL67RSSS is offline   Reply With Quote
Old 05-02-2014, 01:54 PM   #14
Inuyashas_Brother
* Passenger rear
* Driver front
* Driver rear
* Passenger front
BUMP
19" Camaro Wheels over Brembos... on G8 GXP? Tremek Wheels and Tires Talk Sponsored by The Tire Rack 9 11-26-2010 09:24 AM
ABS + bleeding brakes = ? booenson Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 11-13-2010 05:50 PM
Questions about gravity Bleeding Brembos Mr. Brownstone Suspension / Brakes / Chassis 9 09-23-2010 05:21 PM
Brake Bleeding - Wierd RetiredRacer Suspension / Brakes / Chassis 12 07-06-2010 11:05 AM
Red Brembos! Speedy1975 Cosmetics and Lighting Modification Discussions 83 01-04-2009 11:07 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
