04-21-2021, 01:57 AM | #1 |
Drives: 2014 Camaro SS 1LE Join Date: Oct 2019
Finally Getting Somewhere
Been a process but finally seeing the fruits of the labor.
Getting deeper into the track day scene. Recently upgraded the 1LE Spec Stage 3 w/tick performance goodies Oil Pan Baffle/Windage Tray/Crank Scrapper upgraded Grams LT Headers w/Cat Deletes New Plugs/Wires White Brey Krause Harness Bar White Braum Elite X seats Z28 Brake Ducts - next week Z28 Belly Pan - next week Splitter - next week Nankang NS2R 285/35/20 200TW - i had them heat cycled so their ready. Not quite all back together but close enough to run full weekend Chuckwalla Valley Raceway this weekend. Hopefully the Suburban gets the Camaro/trailer their n back. Thanks to Full Throttle Kustomz for their expert advice and work. Final tune tomorrow. More pics this weekend. |
04-21-2021, 06:42 AM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
That’s gonna be one hell of a fun ride. How much do those seats weigh? And do they recline?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-21-2021, 08:22 AM | #3 |
Tri-County Camaro SWFL
Where did u get a Z/28 belly pan from?
04-21-2021, 08:41 AM | #4 | |
I gained maybe 3” in headroom. Which is what i needed to clear the helmet. Ill look into the seats angle next. They sit a little flat for my taste. |
04-21-2021, 08:46 AM | #5 |
www.findlay.com
2 choices. Z28 is the same as the ZL1 BUT lighter. Haha. It has a couple of small sections near oil pan that have been removed. I think the Z28 was $65 ZL1 was $110. Plus shipping of $35 and a couple bolts n clips i bought. Ill take a pic later today. |
04-21-2021, 09:17 AM | #6 |
Here pic.
The open slots are the difference between the Z28 n ZL1 Somehow i got 12 nuts instead of the bolts. And the retainer clips look too small? Last edited by shu92870; 04-22-2021 at 12:26 AM. |
04-21-2021, 10:22 AM | #7 |
I would edit out your name and shipping address ^^ there has been a lot of spammers here lately
04-22-2021, 12:27 AM | #8 |
04-22-2021, 05:17 AM | #9 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Retainer clips look right. I remember thinking they looked small but they worked.
04-22-2021, 12:34 PM | #10 |
