![]() Drives: 2011 Camaro 2ss Join Date: Jun 2016
Wheels for Autocross
I am trying to find smaller, lighter, somewhat inexpensive wheels for my 2011 Camaro 2ss to use for autocross. My understanding is that the smallest wheels which can be used in the FS class are 19x8 on the front and 19x9 in the back - I would prefer to use the same size all around, but I don't think that's allowed in FS class.
Can anyone recommend light and inexpensive wheels of this size? (under 1.5k USD for 4 or under 1k would be even better) I was thinking possibly APEX Arc-8 19x9s in the back, but they're a little pricey. Haven't found a good 19x8. If you'd like to reccomend some 200 tread tires for these odd wheel sizes, I'd also be interested in that. Info on stock wheels and tires here: http://www.camaro5.com/forums/wiki.p...WHEELS___TIRES |
![]() Drives: '16 FiST Join Date: Apr 2012
Ya maybe the apex ps7's or arc's. Have you considered just getting a second set of oem wheels?... You could get a set of rs3's in 20"
I would like to run as small a diameter as is allowed in the FS autocross class in order to fit larger tires on.
Doesn't look like you can fit very fat tires on the 20s without significant rub. Seems like the ps-7 is very similar to the arc-8. Unfortunately, neither comes in 19x8 By the way, if I can run non-staggered wheel widths in street class, please let me know. This would definitely make my life easier. |
No, in FS you need to run 8's & 9's in non-1LE trim. I called the rules guy at the scca to make sure. You can fit fat tires the way it sits without rub. If you stay with 20", a 265 and 285 rs3 will do just fine, there is no benefit to go wider.
#5 | |
By rs3 do you mean hankook rs3 tires? I don't know very much about all this wheel and tire stuff. Thanks for your help, by the way. |
#6 |
![]() Drives: Camaro 1LE Join Date: Nov 2015
If you are getting autocross-only tires. Really depends on how crazy you want to get. I would get 19" wheels and RE-71R tires. A hotshoe in a 6th gen Camaro is running 265/275 on 19x8.5/19x9.5.
#7 |
Get any size you want and run CAM-C!! You can never be competitive nationally in a non-1LE car anyway since you are so limited on tire size and compound...
I run 18x12 with 335 Rival S's all the way around. Last year I ran 305x20 Hankook R-S3 square setup, the kooks cannot keep up with the Rival S and the RE-71R. But they are a great tire for a local only driver who wants to street drive them a lot too. If you are stuck on running FS then you should get 19" wheels in the standard 8" & 9" widths with 5mm less offset and use 255x19 and 285x19 RE-71R's, that's your best bet with those constraints.. I personally run Forgestar F14's and they are great quality, rotary forged, light weight and affordable. |
#8 | |
#9 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
We are on 19" forgestar CF5V's this year the set cost around $1700 for custom ordered offset (7mm allowed offset change with street class) but like cornercarver said cam-c might be worth thinking about for a non 1LE car if your ever thinking about running at a national level event.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
#10 |
![]() ![]() Drives: 2014 2SS/RS 1LE Join Date: May 2013
As others have mentioned if you want to stay in F-Street class you need to keep the original wheel widths but you can go up or down one inch in diameter and the offset needs to be + or - 7mm from stock. 19in wheels will give you a few more options when it comes to tire selection specifically the Bridgestone RE-71r. Sadly it is true that you will be at a disadvantage against 1LE's and their wider stock wheels, but it will be cheaper to run FS than to do the necessary modifications to be competitive in CAM. I know all of the cars running FS in Central Carolinas Region SCCA and I am pretty sure with some good tires and good driver mod you can beat both of the Mustangs that run at those events. If you just want to learn and have fun come out and join us and run FS for a bit (or Novice if you are new, you get an extra run and novice instruction) and then decide if you want to go big in CAM after you have had some more seat time.
BTW I just posted the details for our next CCR-SCCA event over in the South East regional forum here http://www.camaro5.com/forums/showthread.php?t=457413 Hope you can make it. If you are going to attend please PM me.
#11 | |
I'm here on the camaro5 forums following up on your advice about smaller wheels. I don't necessarily plan on buying new wheels soon as currently the part of the car with the most potential for improvement is the driver. But, I like to plan ahead for things. I'm already signed up for the event on the 19th (firmly in the novice class). See you there. |
#12 | |
#13 |
I found some very cheap wheels on ebay that look like they'll fit and are the diameter/width that I want.
They are Privat Weidens, and here are the ebay links: http://www.ebay.com/itm/19x8-Silver-...-/371662596462 http://www.ebay.com/itm/19x9-Silver-...-/361609314984 Will these actually fit? Are they going to break immediately? Will they be warped or otherwise unusable for autocross? For under 600 bucks I don't really care if they aren't very weight efficient - going down from my current 22's will save a ton of weight anyway. I also feel this is a good price point for a beginner like myself. An alternative link for the privat weiden 19x9's claims to fit a camaro ss according to ebay, and there are some 20 inch versions being sold on the camaro5 forums. Has anyone actually put these rims on their camaro? |
#14 | |
Another thing to consider is that you will be asking a lot from these wheels when autocrossing in a very heavy car, and I would not recommend going the cheap route unless they are known quality wheels. I have seen pictures of wheels cracking and failing during autocross and track days. You can probably get away with it but why take the chance? I will have to leave it to others here to make brand recommendations since all I have are the stock wheels on my car. I have heard good things about Frogestars and MRR wheels but no first hand experience, however they may not make them in the size you need. I was poking around the internets but couldn't find many options for you I will ask on the CCR facebook for some brand recommendations unless someone here has the perfect solution.
