Old 02-03-2012, 10:28 PM   #1
2L82RUN
Drives: ABM SS/RS
Thumbs up Pfadt rear end upgrade
Following are pics of some Pfadt upgraded goodness!!! Spent all day Saturday a few weeks ago with a couple friends and installed:
Rear trailing arms/bushings
Toe rod arms/bushings
Differential bushings
Solid subframe bushings
Already had installed:
Solid motor mounts
Front and rear sways with adjustable end links
1.25" drop springs
Took her out today for a little leg stretching since getting her aligned after the install. WOW!!! So much better and stable now that the rear has been blessed by Pfadt!! Very direct feel of power hitting the ground instead of hopping and stepping out to the right like she did prior to the install.
I've picked up a bit of vibration around 2500rpm but I'm attributing that to the solid motor mounts. Nothing bad, but just enough to notice a difference over the stock setup. To me this is a sports/muscle car and I don't expect it to ride like a luxury car anyway. I like the feel of the road!! Can't wait for the upcoming Spring to get some more miles and hopefully some track time. The car definitely feels much more 'planted' to the ground now when nailing the throttle! Too bad all these beautiful components are under the car where no one can see them:
2L82RUN is offline   Reply With Quote
Old 02-04-2012, 05:41 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Nice. I really like the tunnel brace.
Old 02-04-2012, 11:42 AM   #3
2L82RUN
Drives: ABM SS/RS
Thanks! I found the tunnel brace from a member on here that is selling them. Momentum Autosports. It's a very nice piece and was only $60 shipped. As an added bonus the color very closely matches all the Pfadt goodies!!
Link for the brace: http://www.camaro5.com/forums/showthread.php?t=187718
Old 02-04-2012, 07:10 PM   #4
GraysonPeace
"Go on the last yellow.."
GraysonPeace's Avatar
Drives: 2010 2SS/RS L99 CGM
Now you can do 45mph u turns!
Blown and built by Ty Sochacki, tuned by Jeremy Formato. Member of the 11 second club.
GraysonPeace is offline   Reply With Quote
Old 02-05-2012, 06:42 AM   #5
Apex Motorsports
I almost spit coffee all over my keyboard. That brought back an old memory that might violate COC rules if I were to share.
Old 02-06-2012, 10:21 AM   #6
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Great Setup! Glad you're enjoying the new parts, the solid subframe mounts really do make a huge difference in how the Camaro launches.
By the way, sweet tunnel brace. Orange is looking good under there!
Old 02-06-2012, 10:27 AM   #7
Nessal
Drives: Exige, Miata, Ghia
In my last car, I replaced the motor mounts to solid motor mounts as well...holy crap did the car vibrate at low RPMs! But the car launches soooo much more stable. Totally worth it! It just gets tiring explaining why my car makes that noise to guests. hahah
Nessal is offline   Reply With Quote
Old 02-06-2012, 10:33 AM   #8
HumanWiki
Drives: Car
Which suspension package does she come with?
HumanWiki is offline   Reply With Quote
Old 02-06-2012, 10:53 AM   #9
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Nice! Give the motor mounts some time to "break in" and they won't be quite as bad, although you'll still see some vibration at low rpms. If you haven't done so already, replace the trans fluid with Royal Purple SynchroMax, and the diff fluid with Royal Purple MaxGear 75w90. The gear noise level will drop considerably and the drivetrain will operate with less resistance.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 02-06-2012, 01:29 PM   #10
PfadtRacing
Well our Motor Mount kits aren't solid piece, we do use 2 polyurethane bushings as a layer of Noise/Vibration/Harshness isolation. Typically they're a little stiff for the first few hundred miles, but should calm down quite a bit as you drive them a little bit.
They aren't solid, but they're stiff enough to still be a performance improvement and not just a pretty orange mount under the hood!
Old 02-06-2012, 03:03 PM   #11
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
how hard was it to put these pices on?
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 02-06-2012, 04:50 PM   #12
2L82RUN
Drives: ABM SS/RS
I had a shop do the motor mounts cause I wasnt' sure I could do it myself. Turned out they did it without much trouble. Had to jack the engine up just enough to get the old ones out and the new ones in. Also had to remove the drivers side header to get that one done.
The rear suspension parts weren't too bad. I did have a lift and tranny jack that were a big help. Also had two friends spend the whole day with me and we were able to complete the whole project in one 10hr day. Removing the stock bushings was the biggest PITA we had to deal with.
Heres a time lapse of our mod day!!
Old 02-07-2012, 01:15 AM   #13
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Very nice and great choice on the components!!!
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
NEW Pfadt Rear Tie Rods: $210 SHIPPED Trail Arms And Tie Rods: $395 SHIPPED at APEX!! Apex Motorsports Suspension / Chassis / Brakes 32 11-16-2013 09:15 AM
Pfadt Sways | In Stock | Best Prices | Free Shipping! JDP Motorsports Suspension / Chassis / Brakes 121 08-30-2012 05:07 PM
Camaro5Fest III location nomination Atti2de 2012 Camaro5 Fest (III) 2717 05-30-2012 11:59 PM
PFADT FRONT AND REAR SWAY BAR END LINKS toonlovescheryl Suspension / Chassis / Brakes 15 10-15-2011 01:25 PM
HOW TO: Get rid of UNDERSTEER on C5 member Buffnshine's Camaro PfadtRacing Suspension / Chassis / Brakes 6 08-31-2011 09:51 AM
