07-29-2012, 11:45 AM | #1 |
L99 cam sensor question
I am planning to install a cam in my car soon. I will either go with the VVT-3 cam or delete VVT and put in a large LS3 cam.
My question is regarding the cam sensor. I know that regardless of which method I go with the same cam sensor will be used but if I delete vvt and install an LS3 front timing cover, will I need a new sensor cable or can I use the existing cable? Seems some folks had a new cable and sensor installed and I am wondering if that is really required. Thanks
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
07-29-2012, 12:23 PM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
you can modify your bracket and harness to work with the ls3 style cover
07-29-2012, 12:34 PM | #3 |
Thanks! I wonder what's involved in modifying the harness. I don't mind buying a new cable if it makes life easier though.
07-29-2012, 01:16 PM | #4 | |
just modify the bracket and zip-tie the extra plug for the vvt to the side
07-29-2012, 01:58 PM | #5 |
Sounds good man! Appreciate the input.
07-29-2012, 02:48 PM | #6 |
Just cut the wires out of the harness for the vvt sensor if you delete it. I just did one 2 days ago. You'll also have your afm sensor plug left loose on the back side of the valley cover.
07-29-2012, 04:03 PM | #7 | |
I see that you have the mast vvt cam. Do you have any videos of how it sounds? Also, how is it driving with that 3200 stall? Thanks
07-29-2012, 04:50 PM | #8 | ||
07-29-2012, 04:59 PM | #9 |
Sounds badass! Thanks for sharing. I love the shifts at 7k. Was the 3200 required for that cam? Just wondering if you could have gotten away with a 2800-3000.
07-29-2012, 05:01 PM | #10 |
You'll need at least a 3200. I'm restalling to 4k
07-29-2012, 05:16 PM | #11 |
wow 4k? I guess my friend is right about getting a 3800 on his big ls3 cam
07-29-2012, 05:37 PM | #12 |
Yes....lol
