01-07-2013, 11:57 PM | #1 |
Drives: '10 2LT/RS, '13 Malibu Join Date: Nov 2009
10.5" wheel width question
Does anyone have pics of 10.5" wide wheel on the rear of their car? I've been looking at wheels for a while now and came across some that have that width, but makes me a little nervous that the wheel will stick out past the fender. The max width I've been looking at is 10" and feel thats pretty maxxed out for fender clearance. Opinions? I know the offset would make a big difference too and they have a +20 for the rear. Also, what size tire are you running and any fender rub? Thanks for the help!
01-08-2013, 06:22 AM | #2 |
Drives: 2011 Camaro 2SS Join Date: May 2012
Ive been trying to find the same info
2011 Camaro 2SS - SIM - M6 + Mods haha
01-08-2013, 07:02 AM | #3 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
There's some ppl running 11 inch on there widths with no problem as long as the offset is correct you wont have any rub at all
01-08-2013, 07:08 AM | #4 |
A 10 or 10.5 wide wheel with +20 offset mounted in the rear will stick out past the fender. A typical offset for an 11" rear wheel is +42 to +48.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
01-08-2013, 07:37 AM | #5 |
Drives: 2012 2LT 45th convertible Join Date: Jul 2010
I have 11's on mine fitted with 315's in the rear and no clearance or rubbing issues, I forget the offset numbers but I'll check and edit this post with them. suspension is stock.
Top Ten Reasons I Procrastinate
1. |
01-08-2013, 07:59 AM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
Even a 9 inch wheel will stick out past the fender if the offset is wrong. Stick with a reputable vendor (Nineball) and you won't have to worry about your tires sticking out. 20 x 9 in fron, 20 x 11 in back.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
01-08-2013, 08:21 AM | #7 |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
I'm running 10.5 +35 all around
01-08-2013, 10:41 AM | #8 |
Couldn't agree more. A reputable vendor will know the correct offset. As will a good manufacturer. FWIW, Forgeline has the wheel fitment on the 5th Gen nailed. 9.5 on the front and 11 in the rear on mine. No rubbing and they don't stick out.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
01-08-2013, 11:06 AM | #9 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
Check my thread. 10.5 all around, 315 on the rear, 295 up front. The wheels stick out about a centimeter. And IMO, they look fantastic on the 5th gen. A little poke looks EFFIN awesome, plus the car handles like a porsche now lol.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
01-08-2013, 11:33 AM | #10 | |
Drives: 2015 2LT Torch Red C7 Stingray Join Date: Jul 2012
I don't have a very good picture of it but here goes... |
01-08-2013, 02:04 PM | #11 |
movin' down the motorway
Drives: Summiit White 2SS/RS/M6 Join Date: Feb 2010
I've just started looking into mini-tubbing. I want to do it purely for looks and I was initially going to spend the money on a supercharger, but I'll never use the extra hp.
417 stroker - Florida Speed and Power
01-08-2013, 04:00 PM | #12 |
Drives: '10 Blk Camaro SS/'08 Blk Silverado Join Date: Feb 2011
Have Forgelines 9.5" front/11" rear w/NittoInvo's 275-40-20front/
315-35-20 rear Had Nineball(tony@DeviantMotoring) here on C5 sponsor list get the app offset..... Mine works real well! |
01-08-2013, 04:31 PM | #13 |
Drives: 2013 2SS/RS Victory Red Join Date: Jul 2012
Just about flush with fenders sits inside a bit
22x10.5 +38 , 295 wide |
01-08-2013, 04:44 PM | #14 |
Drives: 2012 SLP ZL600 #15 (IOM) Convert Join Date: Dec 2011
I believe the ZL1 is running 11" in the back - so if the back spacing is correct it can be done.
