06-15-2013, 10:41 AM | #1 |
Trans temperature on A6
What should the trans temp be at cold start first thing in the morning? This is what mine shows. Is this right? I don't recall if the gauge should start off at 30 degrees and slowly climb up to say 180 while driving for some time. Is this normal to start off this high on a cold morning after the car has been parked overnight?
I am wondering if my gauge is showing a false reading because I noticed yesterday that it climbed up to 230 for the first time while sitting in traffic on a nice 75F day. The most I've seen it go up in the past is 180. I have a 3600 stall and ADM trans cooler and never seen it go up this high before especially while sitting in traffic. thanks
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
06-15-2013, 11:05 AM | #2 |
knows 2 facts about ducks
That's fine for a cold start, especially considering the ambient temps we've been having.
06-15-2013, 11:06 AM | #3 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
It might be a couple quarts low. 220+ is death valley!
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
06-15-2013, 11:53 AM | #4 |
I was sitting in traffic and the trans was in manual mode. The M started to flash. I put it in D and the D was also flashing. I then realized the trans was getting hot and it stopped shifting past 3rd. At this point tap shifting was completely disabled. I pulled over and turned off the car for 2 minutes, restarted and all was ok but the trans stayed at around 230 for the rest of the drive home. Check engine light came on and it's throwing p0700 and p0716 code. I deleted the codes and it seems fine for now. Not sure whats going on but others experienced same problem on stock car.
06-15-2013, 08:18 PM | #5 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Trans should not be getting that hot. I have a Yank 2800 and ADM cooler. The most I think I have EVER seen is between 190-200 on a 110* day and heavy traffic. Most of the time it stayed around 180* fully warmed up on a hot day. Something is wrong. I would get it checked out ASAP
06-16-2013, 05:16 AM | #6 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
The P700 is an informational codes states there is a trans code.
P0716 means the transmission input speed sensor( AKA: turbine speed ) signal has been lost/no reading. That code will give you the no shift condition. |
06-16-2013, 05:25 AM | #7 | |
CamaroFans.com
06-16-2013, 06:45 AM | #8 |
The thing to do is have you tuner turn the fans on high at a lower temp. That will help keep the transmission cooling temp lower in stop and go.
06-16-2013, 07:56 AM | #9 |
Drives: 2010 Camaro Join Date: Feb 2010
230 and you will cook the trans very quickly. Don't ask me how I know. You have a problem. Maybe a line is partially blocked, something. Way to many parts to diagnose on a keyboard and since I stayed at my house last night and not a Holiday Inn I'm dumber than ever!!
I can hot lap my car in 100 degree heat at the track and I'll never see above 180. That's a log temperature, not the idiot gauge. |
06-16-2013, 08:21 AM | #10 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I have a stall + ADM cooler, and I never see over 180F on it. Good luck on the fix
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-16-2013, 08:25 AM | #11 |
Drives: ZL1 Camaro Join Date: Feb 2009
Your clutches are gone or very near to be gone, pull pan and look at your oil, most likely you'll need to rebuild your trans....I've been there twice!
06-16-2013, 03:52 PM | #12 |
Drives: 2011camaro SS Join Date: Nov 2012
I also have a 3600 Stall and Adm cooler and mine usually is between 175-180 under normal driving! If I run it WOT a couple of back to back 1/4 passes on the street, it may go to 190.
Sounds like there is an issue. |
06-18-2013, 01:07 AM | #13 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
I agree , better get that trans checked out.
06-18-2013, 07:40 PM | #14 |
It seems to be back to normal now after I turned the engine off and back on. I drove it about 10 miles last Sunday for a photo shoot and everything seems normal, the temps didn't go above 180. WTH? I'm afraid to drive it 28 miles to work in traffic though.
