07-30-2013, 08:49 PM | #1 |
Need advice launching with 3600 stall
What's the best way to launch at the drag strip without spinning out? My car is cammed with stock tires. I've never raced on the drag strip before and can use some advice. I have a 3600 PI converter. Thanks
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
07-30-2013, 09:20 PM | #2 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
... Not try to hook on stock tires at the grove.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
07-30-2013, 09:35 PM | #3 |
Sorry i don't understand the comment. What is the grove?
07-30-2013, 09:44 PM | #4 |
Drives: 2011camaro SS Join Date: Nov 2012
You need tires period with that combo otherwise you will be sadly disappointed with your ET's. a good DR will help you alot!
07-30-2013, 09:49 PM | #5 |
Yeah i need some serious tires. I guess I'll have to experiment with the throttle and maybe 2nd gear launch. I'm sure the results won't be good though.
07-30-2013, 09:53 PM | #6 |
I guess you are referring to Union Grove. It rings a bell now although I've never been there. I heard nothing but bad things about that place. I plan to run at C5 Fest.
07-30-2013, 10:21 PM | #7 |
Drives: 2013 SS Join Date: May 2013
2nd gear launch? I wouldn't do that.
07-30-2013, 10:54 PM | #8 |
Actually it is perfectly fine to launch in 2nd gear and that's how I launch my car on the spray. Lets me get more power to the ground quicker. First gear is impossible with a progressive nitrous setup, 200 pills, race gas and NANO.
07-30-2013, 11:13 PM | #9 |
Well I learned something new here I did not know that! OP my bad man
07-31-2013, 07:16 AM | #10 |
Drives: none Join Date: Aug 2011
You're going to have to experiment and slowly roll onto the gas, but you're not going to like your times.
My old SS was at a similar power level you're at and with the 3600 stall it would blow the tires off at 30mph. |
07-31-2013, 08:57 AM | #11 |
Writer
Great Lakes Dragaway (Union Grove, WI) is not bad, just some days not hook well.
If you really want to dial in the car you'll have to go there or Byron or NLR. Jeff at Lucas Raceway could very well have the track glued real good so you might do decent. Good luck.
PROJECT HEAVY CHEVY
07-31-2013, 12:52 PM | #12 |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
Rhino, do you have your TCM programmed to start in 2nd? If not, how do you accomplish this?
07-31-2013, 12:58 PM | #13 |
Easy. Tap shift it into 2nd gear, then as soon as you launch shift it up in to D and make the pass. As long as your D tune is the same as your S tune in the TCM, should work.
07-31-2013, 01:19 PM | #14 |
Would it be better to have less gear and actually use the 1st gear in the trans vs. taking off in 2nd with the 3.91's?
I assume the reason for doing this is Bc with 3.91's, nitrous, and the A6 1st gear being so low you would blow the tires away? |
