Old 06-17-2017, 11:00 AM   #1
Zachariah
Drives: Black 2013 ZL-1
body panels misaligned
hey,,! anyone suggest a cure for what i can only describe as a a sunken inward exterior door panel joint? ..unsightly 3/16 gap that seems to start just around the middle horizontal door crease and runs the length of the entire bottom of door.. passenger side. Name:  IMG_0031.JPG
Size:  355.7 KBName:  image.jpg
Zachariah is offline   Reply With Quote
Old 06-19-2017, 01:04 AM   #2
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
You may be able to adjust the inner door joints...If all else fails I'm sure a body shop can get that lined back up...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 06-19-2017, 06:12 AM   #3
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
Door needs adjusting to close that gap. The bolts on the door hinges are how to fix it
Fred 6528 is offline   Reply With Quote
Old 06-19-2017, 07:35 AM   #4
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Typical GM workmanship. Before I would adjust anything, check to see if there are signs of misalignment, such as scuffs, excessive wear on the door striker, non seal of window and doors (if you get excessive wind noise or drafts). In general I do not have body joints adjusted unless its a glaring issue (very noticeable and unsightly). If you are still under warranty then I'd have the dealer handle it; Otherwise look for a top quality body shop to take care of the issue.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 06-19-2017, 08:07 AM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Did someone put it on a lift and squash the pinch weld underneath? That would cause the fender to bulge out. Check underneath for damage.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 06-21-2017, 03:48 PM   #6
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
Fender and Door
I agree.
If under warranty just take it in.
Otherwise take it into a body shop.
If you feel confident enough you can adjust the door and the fender.
Get someone to help you as the door is heavy.
This is done in the hinges on the door, there is not a lot of room, but maybe enough to take up this slack.
If you loosen the fender bolts you can move the fender in and out too.
JANNETTY RACING 750 ROUGH IDLE CAM PACKAGE
(681 RWHP & 643 RWTQ) = 783 CRANK HP & 740 CRANK TQ
AMMUSCLE is offline   Reply With Quote
