Old 06-15-2023, 11:42 AM   #1
sbelyo
Drives: n/a
How hard is it to install new injectors?
So it looks like I'll need bigger injectors. How hard is it to change them in the garage? I've never swapped them out before.
I calculated 850cc should be fine as my current setup is with stock injectors showing a IDC of 126% at times. I think these will work https://fuelinjectorconnection.com/p...0-cc-for-cts-v or are these better? https://deatschwerks.com/collections.../16u-00-0090-8
I also just got a quote of $600 installed with injectors. That includes me trading my stock injectors. $775 for a tune and $500 for a flex fuel install. That seems fair to me.
sbelyo is offline   Reply With Quote
Old 06-15-2023, 02:35 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
They are not hard to swap out. If you have a trailer just do them yourself. You won’t be able to drive on them without a tune. If i were you i would do the flex fuel sensor myself and save the money, it’s easy. 10 minute job. $775 for a tune is a great price specially if it includes a flex tune also.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 06-15-2023, 04:11 PM   #3
bsn
Drives: 2013 ZL1
On a ZL1 its a little tougher than a normally aspirated just because you have less room- not too bad though. Make sure you buy injectors that come with good data. Since you have HP Tuners you can change the data yourself. i would recommend the Injector Dynamics ID1050X, they cost a little more than the competition but the data is spot on and quality is second to none. A flex fuel kit is a breeze to install but tuning for it is a little more involved, LSA's love E85.
bsn is offline   Reply With Quote
Old 06-15-2023, 06:49 PM   #4
sbelyo
Drives: n/a
Yeah the price was pretty darn good form Jeremy at fasterproms. He's 2 hrs away from me in Clearwater
$600 for 850 cc injectors installed (trading my stock ones to him for the labor)
$500 for the flex fuel parts and install
$775 for the tune including E85
$50 for 10 gallons of E85 (bringing car in with 1/4 tank of 93)
Comes to $1925
He says to keep my 2.5" top pulley as it's safe. I have a 2.75" that I will swap in just to make sure I don't go anywhere near maxing out in the IDC until he tunes it. Plus I'm not used to the car just yet
Old 06-15-2023, 10:14 PM   #5
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
ID850’s where discontinued in 2017 and replaced with the ID1050, so this guy has been sitting on these for almost 6 years.
ZMEnow is offline   Reply With Quote
Old 06-16-2023, 09:46 AM   #6
sbelyo
Drives: n/a
We didn't discuss brands or part numbers so not sure what would go in there until I get there. He said 1000 cc was also an option so I don't know specifically what I'll wind up with.
Old 06-16-2023, 12:14 PM   #7
bsn
Drives: 2013 ZL1
If your running E85 you want 1000cc over 850cc for room to grow, you also will need more fuel than the stock fuel pump-think real hard about adding an aux pump because E85 requires about 30% more flow.
Old 06-16-2023, 03:34 PM   #8
ZMEnow
Would not put anything in but a Injector Dynamics.. ID1050 can take more pressure for growth and has a better pattern than the 850..
