Old 03-19-2016, 10:01 AM   #1
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
Battery Tender
Quick question, does a battery tender have to hook straight to the battery or can it hook to the + port and - terminal under the hood?
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
Old 03-19-2016, 10:32 AM   #2
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Under hood is fine.
MMC is offline   Reply With Quote
Old 03-19-2016, 10:33 AM   #3
DrkPhx
DrkPhx's Avatar
I hook mine up to the front and have never had a problem and it works fine.
Old 03-19-2016, 10:34 AM   #4
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I have a tender but I hooked straight to the battery. Other members have posted, and say you can hook them up under the hood it and works just fine. You'll still be sending a charge to the battery so you should be fine. Maybe some who has actually gone this route will chime in.
HOJO is offline   Reply With Quote
Old 03-19-2016, 10:50 AM   #5
MYLSA
MYLSA's Avatar
Drives: 2014 ZL1 6M
Hmmm...the tender I had for my 911 TT just simply plugged into the accessory
power outlet inside the cabin...then you would just carefully shut the door on the wire (made sure it was loose each time) and then plugged the tender into the wall??? Maybe the one for Camaro works different???
2014 ZL1, 6M, Summit White/Black, Carbon Fiber hood insert
2014 2SS/RS LS3 "sold"
ZL1 Exclusive Member
MYLSA is offline   Reply With Quote
Old 03-19-2016, 11:11 AM   #6
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
Hmmm. The acc outlets in the cabin shut off when the key is turned to off. Don't know if backfeeding voltage into the system would actually go anywhere?
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 03-19-2016, 11:22 AM   #7
ELIC1
Drives: black and silver
this is the one i use and love it... i hook it up under the hood to the battery post and the bolt under the engine cover works great
ELIC1 is offline   Reply With Quote
Old 03-19-2016, 11:24 AM   #8
zeeb
zeeb's Avatar
Drives: 2014 ZL1, AGM, M6
The ports are electrically the same as the battery posts
zeeb is offline   Reply With Quote
Old 03-19-2016, 02:18 PM   #9
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Hook it to the red cap port, and ground it and your good to go.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 03-20-2016, 12:19 PM   #10
sengli
sengli's Avatar
Drives: 2017 M6 Red Hot ZL1
I hooked mine up to the battery directly. Ran the hook up line under the edge of the trunk liner and it is just inside the trunk lip. I pop the trunk, attach the lead, and put the trunk lid down, not latched, for charging. So in your case you would pop the hood, to access the terminals in engine compartment. I chose to pop the trunk, to go directly to the battery.
sengli is offline   Reply With Quote
Old 03-20-2016, 12:39 PM   #11
68rssscamaro
Camaro: A Legend Reborn!!
68rssscamaro's Avatar
Drives: SOLD: 12 2SS/RS LS3 45th
+1
I did the same as above.
As for a charger I use a Sears Diehard charger, and have had no problems so far. I paid 35$ on sale.
http://www.sears.com/diehard-platinu...Q&gclsrc=aw.ds
[SIGPIC][/SIGPIC]
68rssscamaro is offline   Reply With Quote
Old 03-20-2016, 12:59 PM   #12
ELIC1
i hooked up the loops that came with the battery tender so all i have to do is plug it in... its way better then using the clips
Old 03-20-2016, 01:03 PM   #13
hammdo
'It's an experiment'
hammdo's Avatar
^^^ this is what I did also, much easier... if you drill a small hole and use a rubber grommet, you can run the wires though and just plug it in from the bottom, never having to open the trunk -- though that is not for everyone...
-Don
747 RWHP 794 RWTQ
Old 03-20-2016, 01:08 PM   #14
ELIC1
-Don
