JUICEDMOTORSPORTS
Old 06-05-2018, 02:33 PM   #1
RubyCamaro
Jan
RubyCamaro's Avatar
Help with ACS hood liner installation problems
Okay I need some help from folks with ACS hood liners. I had mine custom painted but install is not great. It does not fit flush even when pushed firmly into place (like maybe it is a bit distorted /warped. Then when I drive around, the front part comes even further away from the hood (maybe an inch or so). We have tried using some 3M tape & even the Gorilla super grip version, in strips along the front but it is not holding. I have heard some folks ended up gluing theirs in but I'm not sure I'm comfortable with that. What have you guys/gals tried or suggestions?
Old 06-05-2018, 03:11 PM   #2
farm rat
farm rat's Avatar
Drives: 2011 Vistory Red 1LS
I am of no help, but that looks beautiful if you can get it to work.
The Original Farm Rat
2011 1LS M6 Victory Red
Sold
1967 Coupe Green and White
1969 SS 396 Hugger Orange
1969 Z/28 All original White with deluxe interior
1970 RS Blue
1978 Coupe Fugly Green
1978 WS-6 Trans-Am Factory 4 speed
1985 IROC-Z Red
farm rat is offline   Reply With Quote
Old 06-05-2018, 04:02 PM   #3
RubyCamaro
Jan
RubyCamaro's Avatar
Thanks. Hopefully I will find a suitable solution.
Old 06-05-2018, 06:44 PM   #4
BAD DAB
BAD DAB's Avatar
Sorry Ruby I don’t have any information but I have to say that your hood liner looks great! Hope you can get everything straightened out.
Old 06-05-2018, 11:25 PM   #5
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Hi Ruby , Thats one sweet looking hood liner . Any ways 1st thing did you check the retaining clips before you mounted the liner . Make sure the ridges were all new , no bent or distorted ones . I had one on mine and replaced it . I did a test fit to make sure all the push pins lined up . Then a couple of then didn't catch right , I had to really apply pressure to hear them seat good into the hood . I used a mico fiber cloth to push on . they finally clicked in . I also took some door edge guard trim found at Auto Zone and put around the edge of the liner for a tighter fit and finish look. I hope this helps . the only other thing is to make sure of the brackets holding the push pins are not sitting to high off the liner to make it flush with the hood . You can also contact Joesph he has a lot of tips for installing his parts . Hope this helps .
Bio-hazard
BIO-HAZARD is offline   Reply With Quote
Old 06-06-2018, 09:27 AM   #6
RubyCamaro
Jan
RubyCamaro's Avatar
Thanks guys. Retainer clips were all fine & lined up well (much easier than my hubbie's did). I was thinking about doing the edge trim. Glad to know it worked out well on yours.
Old 06-06-2018, 10:22 AM   #7
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
Please let us know how this ends up...was considering buying one
DBHWT is offline   Reply With Quote
Old 06-08-2018, 09:57 AM   #8
RubyCamaro
Jan
RubyCamaro's Avatar
Still don't know what to do. ACS told a friend of mine to put a small amount of caulk on the retaining clips. ACS told me to use an adhesive around the edges. Problem is both of these would be permanent. This was not a cheap mod. What if, my luck, I got a dent in my hood & it needed to be removed to fix the dent? Perplexed.
Old 06-08-2018, 10:10 AM   #9
farm rat
farm rat's Avatar
If it is not flopping around I would do what a poster above did and put some door edge guard around it.
Sold
1970 RS Blue
1985 IROC-Z Red
Old 06-08-2018, 10:08 PM   #10
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Ruby - that is awesome looking! I would use a 2 part epoxy to glue it in if your looking for a fastenerless look. You would need an epoxy that will work for the material of the liner and the clearcoat on the inner part of the hood. Clean extremely good with with a50/50 mixture of water and rubbing alcohol on the areas where you will put the epoxy.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 06-08-2018, 10:11 PM   #11
Jayjellyfish212
Drives: 2014 1LE
I would not worry about needing to remove it. If that ever needs to be removed I would worry about it if that day ever arrived. Get r done.
Old 06-11-2018, 11:49 AM   #12
RubyCamaro
Jan
RubyCamaro's Avatar
That's like saying, "Hum, I think I'll super glue my hand to my face, I won't worry abut getting it off until or unless the need arises". Sorry, too late now.
Old 06-12-2018, 10:20 AM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Have you thought about using Velcro?
Orange Krush II
1LE Front sway bar with DSE Links, Splitter, 3.91 Gears and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Headers, Cats,Toe Rods and UCA Bushings, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels.
Old 06-13-2018, 03:42 PM   #14
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
Silicone caulking always makes a good adhesive if left long enough to cure and you will have no problem removing it and re-installing it in the future if need be. It just needs more time to dry and cure.
davesnever is offline   Reply With Quote
