Phastek
Old 09-10-2018, 06:43 PM   #1
Badmag71
Badmag71's Avatar
Drives: 2010 camaro ss
Drivers side window issues
I am having a window issue, When I remove the key from the ignition and open the drivers door the radio does not turn off and the dome light wont come on like usual. In addition to that the drivers window will not go up or down. I can lower the passenger window from either side but no response on the drivers window. Note that when I disconnect the battery for a while and reconnect the car asks me to index the passenger but not the drivers side. As if there is no drivers side? Anyone else have this problem and what's the solution?
Thanks
Badmag71 is offline   Reply With Quote
Old 09-10-2018, 07:18 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Your driver's side door open sensor is disconnected or broken.
Rock-It Man is offline   Reply With Quote
Old 09-10-2018, 08:34 PM   #3
Badmag71
Badmag71's Avatar
Where can I find that?
Thanks
Old 09-11-2018, 08:23 AM   #4
Rock-It Man
It's part of the door latch, unfortunately, which is behind the door panel.
If the window doesn't step down when the door is ajar, yet you are not getting a door ajar message, the circuit is open.
Hopefully someone here has fixed this and can help. But be aware that the BCM is involved. You could waste a lot of money replacing parts, or you could get a diagnosis from a pro.
Old 09-11-2018, 12:16 PM   #5
Badmag71
Badmag71's Avatar
I agree, no door ajar message, I'm hoping someone has figured it out so I dont spend a bunch on what I dont need
Old 09-12-2018, 10:03 AM   #6
Badmag71
Badmag71's Avatar
Anyone else experience this?
Old 09-13-2018, 09:18 PM   #7
Badmag71
Badmag71's Avatar
Bump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
