Old 01-26-2020, 05:05 AM   #1
aaberg
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
How lift engine from car?
I need to remove the engine (L99) from my Camaro 2012 and are going to lift engine from up. Any suggestions how to attached chain from engine hoist?
I have a engine hoist like this:
Another issue; Any suggestion how to separate exhaust systems parts with out destroying them?
aaberg is offline   Reply With Quote
Old 01-26-2020, 07:49 AM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Usually the car gets separated from the engine on these cars instead of the engine being separated from the car. What I mean is that there are 6 bolts holding the subframe on and you can lift the car up and the engine will stay on the subframe as the car is lifted off. If you don’t have a lift, I can’t help you. Sorry.
As for the exhaust question, hopefully you’ve unbolted the manifolds from the block, but if you want to take them with the engine, there are clamps in your picture that you loosen and then either slide them lose with one still on the factory cat and the other on the catback, or take a slotted screwdriver and pull the tab enough that both clamps can be left on the factory catback. If all you want are the manifolds and not the catalytic converters, there are two bolts that can be accessed from the engine bay with an extension bar to unbolt the cats from the manifolds.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-26-2020, 02:04 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS LS3 Swapped A6
I lifted mine out from the top. Take your front bumper off. I tried doing it with the bumper on and realized I needed the lift 2 inches closer that I couldn't get with the bumper on because of its pointy nose.
Also, be very careful using only the valley cover bolts to lift it out. I pulled a poorly tightened valley cover bolt straight out due to the weight of the engine and the thickness of the metal L brackets on the ends of the chains not allowing allow the valley cover bolt to thread in far enough. Luckily the threads weren't chewed up too bad once it was fully threaded in without the lift connector.
For better angle and leverage I wound up attaching the front chains to a couple of studs /bolts on the face of the heads. You have 3 bolt holes per head/per side to choose from in the front. I still used the valley cover bolts for the rear 2 chains. I used a load leveler that has 4 chains/attach points.
I suggest a hand cranking load leveler because you will need to play around with the angles to lift it cleanly on both ends and to avoid hitting the cowl area. This was my biggest obstacle on the removal. The leveler will allow you to shift the engine forward a bit to avoid the cowl. The most important advice I can give you is to not do this alone. Have 1-2 extra people to help guide the engine during the lift process. The higher you lift the engine, the less control you have of it swinging into things.
I am sure someone else that has removed their engine several times has a better way to do this and will hopefully give input. I wish I could have done it from the bottom, but I just don't have the setup and equipment needed for that.
Edit: Just noticed in your picture that the hoist has a load leveler, so that is a positive. I couldn't imagine trying to do this without one.
2010 CGM Camaro 2SS LS3 Swap A6 - GPI SS1 .646/.637, (224/237, 112 +4) 8620 core, CHE trunnions, heads milled .015, TSP longtubes (Catless), X-Pipe, FM Outlaw axle back, Stage 2 ported throttle body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, Hinson wires/NGK TR6IX plugs, 160* Stat, Vitesse throttle controller, slotted/cross drilled rotors w/Hawk performance ceramic pads, ZL1 leather steering wheel swap, ZL1 Add-Ons wicker bill spoiler, SLP front splitter - Megan Racing adjustable coilovers, Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI
Old 01-26-2020, 02:13 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
TPIS Happy Hooker:
https://www.tpis.com/parts/view/67
-Don
747 RWHP 794 RWTQ
Old 01-26-2020, 08:01 PM   #5
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Originally Posted by hammdo View Post
TPIS Happy Hooker:
-Don
This or something like it. Makes it easy
gunchamp is offline   Reply With Quote
Old 01-26-2020, 08:49 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
TPIS Happy Hooker:
-Don
I love the name of it. Marketing done right.
Old 03-04-2020, 12:33 PM   #7
aaberg
aaberg's Avatar
Update: Lift from top went fine. Had to remove front to get closer.
<a href="https://ibb.co/25y7NZS"><img src="https://i.ibb.co/25y7NZS/20200208-152959.jpg" alt="20200208-152959" border="0"></a>
Old 03-04-2020, 12:41 PM   #8
aaberg
aaberg's Avatar
Old 03-04-2020, 02:18 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Yep. I learned that the hard way. I was like 3 inches from being able to get it out but the bumper was preventing it from getting closer. Luckily it is fairly easy to reinstall as long as you have someone helping you.
Old 03-04-2020, 02:57 PM   #10
aaberg
aaberg's Avatar
Same for mee. A few frustrating inches to short with front on.
Old 03-04-2020, 03:00 PM   #11
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Last time I took the motor out through the top I didn't even remove the radiator. Once it's up a little just turn it sideways next time and use the engine leveler
GJDM
LsxDoctor is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
