Old 02-02-2020, 10:32 AM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Offset diff bushings
So I'm doing rear suspension mods to get ready for the new power from my turbo kit. So far I've peiced together
Prothane cradle bushings, and BMR poly diff bushings , BMR toe rods non adjustable with poly bushings, I'll prob get the same for the trailing arms. My question is do I need the offset diff bushings? My car is lowered with BMR 1.4 inch lowering springs. It's a street car and i will run drag radials for the track. Thanks.
2011 Camaro 2SS L99, 3500 stall, BBK xpipe, muffler delete.
2017 ZL1 (SOLD)
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 02-02-2020, 11:55 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I’d say yes if you’re running that kinda power it’ll help with drive line angles on you axle shafts.
Your axle shafts will be the weak point unless you get some bullet proof ones from DSS, Strange, or 1320 Engineerring.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Suede Steering wheel, short throw shifter. Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 GS Calipers, PAFDT Solid Cradle bushing, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs.
Old 02-02-2020, 09:46 PM   #3
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
Yes takes a little stress away from your drive train when launching
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 02-07-2020, 10:54 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I would, I just installed them for 1.4 drop
Whipple 2.9 CAI ID1050x injectors JMS BAP JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering long tubes 2.5 cat back borla atak ZL1 pump JRE flow control module JRE scoop 1.5" lowering springs BMR trailing arms and toe links WHP TBD
Greenhornet2 is offline   Reply With Quote
Old 02-07-2020, 01:40 PM   #5
IKILLEDSUPERMAN_ZL1
Ordering them today !
2017 ZL1 (SOLD)
Old 02-11-2020, 11:24 AM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
I did for my ZL1 conversion, since my car is lowered on coilovers. It helped with the halfshaft or axle angles.
Currently in the fleet... 2017 Corvette ZO6, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 02-13-2020, 12:19 AM   #7
IKILLEDSUPERMAN_ZL1
Got the Hendrix bushings. These things are nice.
2017 ZL1 (SOLD)
Old 02-13-2020, 06:07 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
There gonna cause a lot of noise!
Orange Krush II
Old 02-14-2020, 09:57 AM   #9
Greenhornet2
Noise vs broken axles, I'll take the noise
Old 02-14-2020, 10:21 AM   #10
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
What noise are you talking about?
Forged 376, E85, milled GMPP ported heads, Night Fury, Vmax TB, GPI rod mod manifold,Improved racing,Melling,ATI, DSE, DW, BTR, Smith Brothers, McLeod twin RXT, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Vararam OTR intake,Tick,Elite CC,Kooks headers/HFC,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017,Continental Extreme Contact, Nitto555R
Black_SS10 is offline   Reply With Quote
Old 02-14-2020, 01:46 PM   #11
hammdo
'It's an experiment'
hammdo's Avatar
They transfer driveline noise (clunks etc.) I've had them for a couple of years now. Had to install them as my axle kept popping out while road racing. These solved that issue for me.
-Don
747 RWHP 794 RWTQ
Old 02-14-2020, 01:58 PM   #12
IKILLEDSUPERMAN_ZL1
I think it's a fair trade off.
2017 ZL1 (SOLD)
Old 02-15-2020, 09:17 PM   #13
NicKey
Drives: Nickey Super Camaro
They are made with two different materials, Polyurethane or Delrin. The Delrin bushings are harder and transmit more noise and vibration.
NicKey is offline   Reply With Quote
Old 02-16-2020, 11:57 AM   #14
IKILLEDSUPERMAN_ZL1
I ordered the poly ones.
2017 ZL1 (SOLD)
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
