02-15-2010, 01:17 PM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
Need a DIY for Boost / Air fuel gauge install
I am having the sc installed next week and am looking for somebody to lead me down the road to find the right guages. I will most likely be using the dual pod from fessler but need to know how to install and what to look for as far as gauges. Looked at the adm ones but they are just too pricey.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
02-15-2010, 02:02 PM | #2 |
Se habla espaņol
Drives: 2010 Camaro SS/RS VR Join Date: Jun 2009
Im in the same boat....the gauges that I like the most are the Autometer Nexus, but they are expensive too.:(
The boost gauge and Air/fuel ratio gauge (light show ) are the ones that Im going to order. Boost and fuel pressure are the ones that most people tend to use.. JM
2010 VR 2SS/RS
BMR Suspension Parts Hendrix HD Axles DSS Aluminum Shaft RPM Diff / 3.91 Gears LPE ZR1 Clutch Edelbrock E-Force SC / JRE Fuel Upgrade Livernois 1C cam 570 rwhp/559 rwtq SAE Best 1/4 time: 11.43 |
02-15-2010, 08:10 PM | #3 |
anybody? Bueler? Bueler?
06-19-2010, 10:51 AM | #4 |
serious? am I the only person that wants to know how to do this? Is nobody proud of their install?
06-19-2010, 03:53 PM | #5 |
Se habla espaņol
I had to paid to get them installed...
The boost gauge looks easy to install but for the AF ratio gauge you have to drill a hole in the headers to install the sensor.
2010 VR 2SS/RS
06-19-2010, 09:46 PM | #6 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
Just drive by a exhaust shop and have um weld a bung in for the af sensor for like 30 bucks route it power and ground and mount and your ready to roll!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
06-19-2010, 10:01 PM | #7 | |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Sorry, just saw this thread so here are a couple of things to consider that I went over with another SC member: The type of gauges you should look for would be 1) a boost/vacuum gauge that sweeps from 30 in of vac to 20 lbs of boost. The boost gauge is great. When you get used to it, you drive to that gauge a lot. You'll know what I mean if you install it. 2) an A/F gauge (preferably wideband). The A/F is a much better tuning item than say fuel pressure since it is telling you what the engine is actually doing, not what it is receiving. If your fuel pressure were to drop, it will show up on the A/F. Plus with a fuel pressure gauge you would have to run the gauge outside or get a pressure transducer to convert it to an electric signal to run inside. Here is a thread where a member has a pic of Autometer Cobalt gauges installed on the drivers A-Pillar. Check out Post #6. http://www.camaro5.com/forums/showthread.php?t=87333 Anyway just my < .02 |
06-20-2010, 07:37 AM | #8 | |
06-20-2010, 07:51 AM | #9 |
SST...
Also, check out the A/F gauge in Post #5 of this thread. That is the level of gauge you really want to have. http://www.camaro5.com/forums/showthread.php?p=2004739
06-20-2010, 10:21 AM | #10 |
Drives: 2011 Fasties Maxies Join Date: Jun 2010
Think this boost guage would look cool?
06-29-2010, 04:17 PM | #11 |
I like it! Did we figure out where to get the power lead and light lead from?
07-14-2010, 06:55 PM | #12 |
Drives: Red Jewel SS Join Date: Sep 2009
What power wires are used? I cant seem to find any....
Ray |
07-15-2010, 05:18 PM | #13 |
Drives: 2010 Join Date: Jul 2009
I would just buy the ADM boost/AFR gauge and be done.
It looks better mounted in the gauge cluster IMHO than that round gauge that you need to find a home for. |
07-15-2010, 05:24 PM | #14 |
where is the vacuum line that you tap into on the maggie?
Similar Threads | ||||
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
Those with LT's, RESET your check engine light! | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 107 | 08-18-2010 01:51 AM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
