02-25-2021, 01:57 PM | #1 |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
Best Differential Oil?
I just received my 3.91 gears and Detroit Trutrac. Planning on doing the install this weekend. Wondering what’s the best / recommend gear oil?
Thanks!
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
02-25-2021, 02:14 PM | #2 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
For a bunch of years I used Amsoil Gear Lube. Worked in everything...except this Camaro! It liked the GM OE stuff better. (quieter) But that’s on a stock diff.
02-25-2021, 03:11 PM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Detroit Trutrac does not recommend synthetics or friction modifiers. (fyi)
Go to their web page for recommendations.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-25-2021, 03:25 PM | #4 |
Ah, good to know. I’ll go check out what they recommend. Thank you!
02-25-2021, 08:19 PM | #5 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I've been using Lucas 85w-140 conventional gear lube with my TrueTrac. I run the Z/28 diff cooler to help keep the temps in check since I track mine.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
02-25-2021, 11:31 PM | #6 |
I have had good luck with the Amsoil Severe Gear 75W-90 in my rear so far (didn't use additional Friction Modifier). But the car is so damned loud that I probably wouldn't hear if it was making noise!
02-26-2021, 07:59 AM | #7 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
I use Mobil 1 with the OE friction modifier.
02-26-2021, 09:32 AM | #8 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Amsoil here as well. Used Amsoil in the 1LE with GM friction modifier. And now Amsoil in the Z/28 without the modifier. Have not had any issues with either and I tracked both
02-26-2021, 10:04 AM | #9 | |
Good to know about the TruTrac recommendation.
