Old 09-20-2010, 09:51 PM   #1
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: Sold c7, in the market!
brake upgrade for 2LT non-rs
i want to install a better brake kit on my car, but i want them to fit under the stock 19 inch rims. i there a brembo kit or baer or anything that people are doing. whenever i do a search its always for SS camaros. oh and how would upgrading breaks affect the traction control and stabilitrack systems?
khabboub is offline   Reply With Quote
Old 09-20-2010, 11:21 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
The ss brembos can go on the lt and ls camaros. It's a complete system swap. Callers aand brake control module I believe... not sure on the technical aspect. Its expensive, that part I do know. What are you doing that requires the brembo size brakes? Or is this just a cosmetic upgrade?
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-21-2010, 07:00 AM   #3
khabboub
khabboub's Avatar
its just cosmetic, but it doesnt hurt to have better brakes, i read somewhere that the brembos dont fit under the 19 inch wheels, only the 20 inch wheels.
Old 09-21-2010, 10:04 AM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
That would be the aftermarket Brembos. I run the Cadillac CTS-V / Z28 brakes on my Camaro with 19 inch wheels and have no fitment issues. The most cost effective upgrade for your would be to grab a set of SS take-offs. They will bolt on. If you want more braking use the GM parts bin and to the CTS-V upgrade.
CTS-V / Z28 Brake Upgrade
Old 09-21-2010, 01:16 PM   #5
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
When we upgraded my 1LT/RS to SS Brembos we had to cut out part of the dust shield on the rear wheels because the rotors are so much larger then the LS/LT's. On the LS/LT's the dust shield bends outward towards the rotors after the radius of the LS/LT rotors but before the radius of the SS rotors so that portion needed to be cut off of the dust shield.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 09-21-2010, 01:19 PM   #6
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Yes, thats the only modification that needs to be done, Or you can get a set of new dust shields so you dont need to cut.
other than that, its a pretty straight forward swap.
christianmotox is offline   Reply With Quote
Old 09-21-2010, 01:24 PM   #7
JusticePete
If you do any amount of auto cross or high speed road course work, just too the dust shields out. Unless you use them to mount brake duct hoses.
Old 09-21-2010, 04:33 PM   #8
khabboub
khabboub's Avatar
i already new about having to cut the dust shield, but i read that the 19 inch wheels were to small for the brembos to bit under.
so if i bought i pai of SS take-offs, the brembos would fit on the car with no problem? keep in mind that i have the 19 inch wheels, not the 20 inch wheels that come with the SS, and RS camaros.
Old 09-21-2010, 04:59 PM   #9
JusticePete
i already new about having to cut the dust shield, but i read that the 19 inch wheels were to small for the brembos to fit under.
My 19" Forgeline wheels fit even with the six piston CTS-V calipers. I have not tried the OE 19s.
CTS-V Brake Upgrade Details
Old 09-21-2010, 06:54 PM   #10
khabboub
khabboub's Avatar
maybe your rims have more clearance room, i just dont want to buy the brakes only to find out that i cant even put them on.
Old 09-21-2010, 07:33 PM   #11
JusticePete
If there is anyone is West Michigan with 19 inch OE rims please call the office to arrange for a quick clearance check. 248.522.8021
Old 09-21-2010, 08:49 PM   #12
khabboub
khabboub's Avatar
thank you very much for this.
Old 10-10-2010, 08:26 PM   #13
khabboub
khabboub's Avatar
has anyone been able to confirm this? i really need to know.
Old 10-31-2010, 05:35 PM   #14
1FINE 69
1FINE 69's Avatar
Drives: 2010 synergy green and a 1991 rs
I would also like to know even through its just a cosmetic upgrade? I have a SYNERGY GREEN with 19" can anyone help me??
1FINE 69 is offline   Reply With Quote
Stainless Steel Brake Lines on Sale MTI Racing Kevin Suspension / Chassis / Brakes 17 12-02-2010 12:05 PM
Have you done a brake upgrade for road course use? ericedelman Suspension / Brakes / Chassis 25 08-18-2010 01:19 PM
SS Brake Upgrade on 2LT RetiredRacer Suspension / Brakes / Chassis 1 05-19-2010 07:28 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 01:44 PM
