05-22-2011, 06:12 PM | #1 |
Banned
Drives: 2010 SS/RS M6 Inferno Orangle Join Date: May 2011
Anyone with a 9" IRS Conversion?
1) How much more does the 9" IRS weigh than the stock components. I've heard it's 60-70lbs heavier.
2) Which differential/posi unit did you go with? I know DSS sells the Strange "S" center section with their kit, which has the option of a Detroit Tractech or a Truetrac. I've heard the Tractech is very noisy and I had a truetrac in another car that made a "linear" gear noise at speeds > 50mph. Anyone have experience with either? |
05-23-2011, 11:26 AM | #2 |
Drives: 2010 2SS/RS M6 Join Date: Oct 2009
I didn't weigh mine, it's heavier, but I wouldn't say it's that much heavier than the stocker. I have 3.90 gears/truetrac/strange s center section and it does make gear noise, but I also installed BMR subframe bushings and control arms at the same time.
05-23-2011, 12:31 PM | #3 |
I didn't weigh it but I would say probably only about 20lbs. I went with a Moser aluminum third member which is about 15lbs less the the strange S case. It is a bolt thru design so you don't have to worry about it twisting. I installed a Wavetrac posi unit with 390 gears and noise is very minimal.
05-23-2011, 01:05 PM | #4 | |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
Thanks for the info |
05-23-2011, 01:16 PM | #5 |
No clunking whatsoever.
05-23-2011, 03:10 PM | #6 |
Drives: 05 GTO Join Date: Jul 2009
Our 9" fully assembled with axles stubs, pumpkin, gears and all the works is about 120 lbs. About 105 without the stubs, that would put it about 20 lbs heavier then the stock center section.
We have had great luck with the Eaton Truetrac as well as the Wavetrac. Nice thing about the Wavetrac is the lifetime warranty, but it is more $. The Gforce 9" kit comes with the stronger 28 spline cv joints and 300m axles with the 9" kits, these are the axles that nobody has ever broken. We are a level 2 dealer for Strange (one level better then WD) so we cant be beat on the pumpkin prices, we are also a dealer for Moser if you want to go with the Moser Nodular case with a Wavetrac posi. Lots of options to choose from. We can supply our 9" kit with 31 spline, 33 spline or 35 spline for the heavy duty 35 spline wavetrac. We keep all these on the shelf and ready to ship. And if your pushing 1500+hp we can build our Pro-Mod axle set up with the larger 33 spline cv joints and 33 spline 300m axles. These are the larger cv joints that are made for a larger axle. Thanks Chris Last edited by GFORCE1320; 05-23-2011 at 05:06 PM. |
05-23-2011, 04:32 PM | #7 | |
Drives: own more cars than i can list Join Date: Nov 2010
we are now stocking diffs also keep in mind this kit comes with the larger 30 spline axles, same style that are used on many 8 second and even some 7 second cars...... |
05-23-2011, 09:43 PM | #8 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
I may be your way in a few weeks
Give me a call and ill let you drive my setup,it has over 20,000 miles and is very smooth. We also use the larger 30 spline axle bar ,with custom cvs,we have seen failures with the smaller 28 spline axle bars so we only use the beefier 30 spline.We match our 30 spline axles to our 31 spline inners,there is really no need to go bigger on the inner spline if the axle itself is no bigger,just like the smallest link in a chain will always break first.If i can set up a ride and drive with you give me a call,we keep these units in stock and ready to ship.
05-23-2011, 11:41 PM | #9 |
Is it true that the 9" differential design is not very efficient? Something about the pinion centerline being relatively far away from the ring gear centerline.
If true, how inefficient is it? |
05-23-2011, 11:45 PM | #10 | |
Not much of a loss for what is gained in strength. Thanks Chris |
05-24-2011, 04:46 AM | #11 |
05-24-2011, 12:53 PM | #12 |
Its inefficient depending on what your comparing it to,my car lost ZERO hp going from the stock Camaro rear to the 9 inch,i will add that Hendrick motorsports the Nascar champs built my rear with there gear so im sure that its setup about as good as you can hope for.The 9 inch makes more contact patch on the gear so it stands to reason it will have a little more resistance but again i seen no lose over the stock setup...
05-24-2011, 09:12 PM | #13 |
Banned
Thanks for the feedback guys. I'm leaning toward beefing up the stock diff with the JRE posi mod, LPW diff cover, LPE 3.91 gears, a DSS driveshaft, and a set of DSS or GForce axles.
I just don't like the idea of adding 40+ lbs and reducing the effective HP at the same time. Kind of sucks because I like these IRS kits, especially how the axles can be unbolted and the center section dropped right out. |
05-25-2011, 10:55 AM | #14 | |
Similar Threads | ||||
Gforce Engineering Fabricated 9" IRS | GFORCE1320 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 210 | 02-25-2012 09:20 AM |
Come check out our 9" IRS kit at CamaroFest | GFORCE1320 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 04-18-2011 02:39 PM |
Introducing the Gforce Engineering fabricated 9" IRS kit | GFORCE1320 | Transmission / Driveline | 1 | 03-04-2011 10:25 AM |
Camaro HID Conversion Kit (non-RS) Special till 12/20/09 $195 | Mecha | Exterior Parts & Accessories | 11 | 05-05-2010 04:48 PM |
