04-27-2017, 09:30 AM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
Driveshaft speed sensor
Anybody install a Driveshaft speed sensor, if so where? Scratching my head hard where i could install one. I need one to run a couple functions with holley dominator
04-27-2017, 01:09 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I have not installed one but what about at the rear of the trans over the driveshaft/yoke area? There wouldn't be any up and down movement there to interfere with the readings.
04-27-2017, 01:54 PM | #3 |
Yeah i was under the car looking at that, might have to machine that transmission flange a tiny bit since it was a small slope. Looked at the rear and it's pretty much impossible to fit anything on the stock diff since the flange is so close to the housing
04-27-2017, 02:08 PM | #4 |
You could also weld on a small bracket to hold the sensor
04-27-2017, 03:07 PM | #5 |
Wonder if they make a driveshaft ring that diameter though? or someone makes custom size ones.
