![]() Drives: 2004 Dodge Viper Join Date: Oct 2019
Cerakote trim restore - any experience?
https://www.amazon.com/CERAKOTE-Cera...xoC6K0QAvD_BwE
Like others, I too want to get the dull black plastic back to it's original glory. Has anyone had any experience with this stuff? My neighbor in the old hood used to paint his guns with this stuff, and he's a picky person. So I know the name is good, just not sure if that particular product is legit. I'd hope it goes on well, because I bet it's a PITA to remove once cured. |
![]() Drives: 2012 1LT Join Date: Nov 2015
I've no experience with the Cerakote product, but unless there's some black dye in it I'm not sure how well it'll do. I did have some luck on the black plastic body cladding on a Volvo wagon with just a ceramic trim coating from Adam's, however the lighter tiger striping was still visible on the plastic.
I have had some success with his Ceramic Black Trim Restore ![]() ![]()
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
cerakote coating works great on guns
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I used it on the quarter panel window frames on my Fiero over the summer. One coat lasted a little over a month in the 90s.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
The product that the shop used when they ceramic coated the car didn't last at all. Nebraska winter has them back to looking dull. Definitely going to try this stuff in the spring.
#6 |
I haven't used this product but have heard from some of my detailer friends that it streaks really bad on black plastics.
Try Carpro CQuartz Dlux Wheel & Trim Coating instead. No streaks, no shiny spots, nice even finish.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
#7 |
I'll give that stuff a shot. The last thing I want is streaky finish on there. Thanks for the heads up!
