09-13-2017, 03:51 PM | #1 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Gears, bearings and more..oh my!
Fresh off the UPS truck and just waiting for the Ford s-spring for the diff mod..should be good to go...plus my secret weapon...GM Master Tech at my local Chebby dealership for any Q's...
btw - this was the last bearing kit on ebay...sorry..lol plan is to post pic's of the process(in my garage, jack stands and hand tools) and then hopefully post updates in my other thread over in drag racin section..stay tuned folks...
09-14-2017, 09:15 AM | #2 |
GPI Sales Consultant
Subscribed! Good luck. You'll LOVE the change - you'll be rowing your way everywhere now!
Got a question about a GPI product? Feel free to shoot me a message! |
09-14-2017, 10:12 AM | #3 |
yup yup! USPS lady just dropped off the last piece of the puzzle, can't wait to pull the posi apart and see exactly what kind of wear is going on with the clutch plates...did a lot of research over in the G8 boards...currently zero probs but with the mileage and plans for more trips to the Q...seems a reasonable upgrade to do...at least I hope so!
09-14-2017, 10:50 AM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Whats the deal with the Ford S Spring???
Orange Krush II
09-14-2017, 11:51 AM | #5 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
x2
What rear gear are you going with?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
09-14-2017, 07:47 PM | #6 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
The ford spring applies more pressure on the clutches of the factory limited slip differential.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
09-14-2017, 09:16 PM | #7 |
sorry..3.91's...and yes the spring is the same one in the Jannetty kit...ebay or CJ pony parts $28..
update..center section is out..took about 2 hrs workin slow..start again in the am...
09-15-2017, 05:24 AM | #8 |
Like dis!!
09-15-2017, 07:45 AM | #9 |
Ya learn something new every day, neat. Is that an issue for people - having the posi not strong enough?
09-15-2017, 08:27 AM | #10 |
Nice! I might need to hit you up whenever I get around to changing my gears!
2010 2SS/RS
09-15-2017, 08:35 PM | #11 |
update..posi section is done....housing is cleaned out...pinion races are a B to get out!...now I got figure out how to get the new pinion race(inner) in...may have to cheat and my mech to help...clutches look great...couple of pics...now I got a long weekend away so prob will not finish tomorrow...also all gear faces are now flat and polished to ride against the spring...
this is stock with bolts out to show gap between housings..used to set preload..
09-21-2017, 10:54 AM | #12 |
quick update...waiting on a couple of posi clutch kit's to arrive...the long weekend gave me the opportunity to review current progress and I realized my initial approach did not take the clutch pack height into consideration...had I tried to run it would have probably gone boom...soooo...everything is back apart and have done additional measurements to make sure it gets back together correctly...hopefully will have more progress soon 'cause I want to get her back on the ROAD!
09-21-2017, 03:00 PM | #13 |
Drives: 03 suburban 72 gto 11 2ss 6m Join Date: Apr 2017
I'm not understanding what you mean by clutch pack height? All I did was install the spring and bolt it back together. Did I do something wrong? Its not noisy and seems to work fine at least for now.
09-21-2017, 07:09 PM | #14 |
how many miles on car before spring and now how many miles after? Also, do you drag the car with DR's? where did you find the info for you mod? tks!
