Old 02-13-2017, 05:08 PM   #1
ZEA28
Drives: 2014 Z28
Z28 Flat tire
Hi All - Drove over a small nail in my garage and fully flattened the front left Trofeo much to my disgust. Z28 does not seem to have a jack and tire iron. I'm supposed to use the emergency inflator kit but I want to keep theat for the road (or is there a jack and tire iron somewhere in the car???). Are the jacking points for the Z28 unusual/any different from any other car? Just pick a point on chassis just inside from the wheel??? Or are there issues to watch out for? Any advice appreciated. Also can a Trofeo with a hole in it be repaired or is it toast now? Thank you very much.
ZEA28 is offline   Reply With Quote
Old 02-13-2017, 07:31 PM   #2
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
I've had two flats fixed with plugs, both on the rear. Both were in the tread, no where near the sidewall. No issue, they've both been running w/o issue since. I bought an amazon kit with plugs, an inflation pump etc. or you but the $$$ GM kit.
Oh and I didn't use the slime...
Here's what I got:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 02-14-2017, 10:21 AM   #3
craZed
craZed's Avatar
Drives: Z/28 15 AGM
Lifting (Jack) points illustrated in this thread.
If you're lifting on the pinch welds (green boxes in the image from the post above), make sure you have a jack designed for it, or appropriate jack pads, similar to these.
A low-clearance floor jack will work on the frame lifting points (green arrows in the image).
craZed is offline   Reply With Quote
Old 02-14-2017, 10:30 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
there is no jack or tire iron included with the Z/28. My car doesn't have a tire inflator either.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:04.53 VIR Full 11.08@126.52 1.76
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-14-2017, 11:25 AM   #5
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
You plugged a track tire? Please tell me you will fix it before tracking it. You know when the tire heats up the plugs come out. Those will not pass tech and it is very unsafe.
Not a one has a jack. Only those sold in states requiring the inflator by law got those.
GM assumed people buying a track car would have a jack. There are two next to my car.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 02-14-2017, 11:56 AM   #6
z28rox
Drives: 2015 Camaro Z/28
Man the stuff you come up with...A plug be no issue at all on the track the plug heats and expands with the tire. Check with Bondurant they do this all the time with their track tires to save on costs. Also NO track checks for plugs on tires ever for HPDE days. Since you are such a wealth on track knowledge what is you SCCA Lic#? or NASA
z28rox is offline   Reply With Quote
Old 02-14-2017, 12:08 PM   #7
frenchsquared
My track does and the Porsche club has. I have no idea what SCCA or NASA does I highly doubt the OP is using his car for that. If I tech that car I am to fail it for plugs. I have seen the Porsche inspector fail a Corvette for plugs. The tech is actually tighter on street cars. If I take my plates of and trailer my vette I get an instant pass. Porsche doesn't even tech track cars. The Porsche tech was not looking for plugs but noticed one. They asked about it and told the guy to get it fixed correctly before the next event.
My SCCA Member number is: 503517. I am still working on my license.
Actually NASA says not to use them
https://www.nasaproracing.com/hpde/preparing.html
Tire rack agrees.
http://www.tirerack.com/tires/tirete....jsp?techid=77
Motor week agrees
http://www.motorweek.org/features/go...or_not_to_plug
Corvette Forum agrees it drops the speed rating.
http://www.corvetteforum.com/forums/...-it-today.html
So... where do I get this stuff... From life experience, common sense and reading what others says.
One more... here are the actually legal rules. You cannot simply plug a Z rated tire.
https://www.goodyear.com/cfmx/web/go...e/psb_9811.cfm
Its not my $50,000 car and I wont be on the track with you so plug away. Personally I will stick with what all those articles say and get the tire fixed correctly.
Old 02-14-2017, 12:17 PM   #8
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
Never plug a tire that you will be driving at high speeds!
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 02-14-2017, 12:34 PM   #9
z28rox
"Guidelines allow the repair of punctures in a tire's tread area of up to 1/4" in diameter. Repair of larger tread punctures and of punctures to the tire's shoulder and sidewall areas are not recommended."
While almost any sharp object left on the road can cause a puncture, most are caused by small nails and screws (typically less than 1/4" in diameter).
From your link
Again nothing about plug dropping out of an expanded hole in a tire. Your SCCA member number must be super new since the newest member number on the SCCA website is still in the 480's.
Old 02-14-2017, 12:39 PM   #10
z28rox
FEBRUARY
3F Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
4S High Plains Raceway High Plains Raceway Details
4S-5 Our Gang Ice Racing Georgetown Lake Details
11S High Plains Raceway High Plains Raceway Details
12S High Plains Raceway High Plains Raceway Details
18S High Plains Raceway High Plains Raceway Details
19S Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
24F Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
25S Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
25S High Plains Raceway High Plains Raceway Details
26S High Plains Raceway High Plains Raceway Details
HPDE Insurance protects your car on track
MARCH
12S Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
17F Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
19S High Plains Raceway High Plains Raceway Details
25S-26 NASA - Rocky Mountain Region Pueblo Motorsports Park Details
26S Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
Speed Secrets Weekly by Ross Bentley
APRIL
5W Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
14F Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
15S High Plains Raceway High Plains Raceway Details
16S High Plains Raceway High Plains Raceway Details
16S Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
21F High Plains Raceway High Plains Raceway Details
21F-23 High Plains Raceway - RV/Carport Reservations High Plains Raceway Details
28F High Plains Raceway High Plains Raceway Details
28F PMP powered by RCSC Motorsports LLC Pueblo Motorsports Park Details
28F-30 High Plains Raceway - RV/Carport Reservations High Plains Raceway Details
29S-30 Rocky Mountain Vintage Racing-RMVR Pike's Peak Int'l Raceway Details
29S-30 NASA - Rocky Mountain Region High Plains Raceway Details
Winding Road Racing - the gear you need to go faster!
MAY
4T High Plains Raceway High Plains Raceway Details
5F High Plains Raceway High Plains Raceway Details
5F Pikes Peak International Raceway Pike's Peak Int'l Raceway Details
Frenchsquared will any of these days work for you to meet at the track for some high speed road course work.
Old 02-14-2017, 12:46 PM   #11
frenchsquared
But they are not just plugged with a $5 kit from walmart. They are properly patched.
Last year. I don't have the money to compete. I am joining a team this year, few friends who will let me share there car and help get my license. This is a very expensive hobby and not everyone can afford to take it to that level. Im trying... That doesn't mean that everyone who doesn't have that license is stupid. Cheap plugs shoved in a race tire are not safe. I would do it in a second to finish a real race... but I would not start the race that way. I would fix it right.
I am planning around 8 two day HPDE's this year. Not racing in SCCA does not mean I am not on a track, around a track or building cars.
Are you in Colorado? Im thinking about doing the Pueblo HDPE in March? I have never done a NASA event and have been trying to find out if I need anything different then the Porsche and Corvette club events?
You should come down to La Junta. I am the VP of the Club.
April 29th & 30th
June 3rd & 4th
Sept 9th & 10th
Oct 21st & 22nd
Old 02-14-2017, 01:14 PM   #12
z28rox
I have not been to Pueblo since my PCA days but fun track except for the drag strip crossing very unsettling. Just wanted to see if you wanted to hook up for an HPDE at a local track. You would love High Plains.
Old 02-14-2017, 01:16 PM   #13
z28rox
April 29th & 30th
June 3rd & 4th
Sept 9th & 10th
Oct 21st & 22nd
I will definitely do one or two of those dates.
Old 02-14-2017, 01:22 PM   #14
frenchsquared
Defiantly... Sent you a PM since we totally jacked the OP's thread.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
