02-26-2020, 01:36 PM | #1 |
Drives: SS Join Date: Apr 2019
Who has the Cheapest Price: DSX Aux and ID 1050x Injectors
Possibly looking for some ID 1050x injectors and the DSX Aux Pump. Who has the cheapest price on them? Thanks.
02-26-2020, 07:50 PM | #2 |
Drives: 11 camaro Join Date: Mar 2017
Got some ID1050X I just took out for some 1300's. Asking $500 shipped if intrested. No issues with them at all.
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
02-27-2020, 06:51 AM | #3 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
I've been semi-looking for a DSX Aux pump as well. The best price I've seen so far is from CSP, I think think it was $950 with their tax sale discount code. Juiced Motorsports sells them as well and offers a discount to Camaro5 members but I'm not exactly sure what it is.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
02-27-2020, 11:20 AM | #4 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Montmotorsports has a dsx kit with injectors on their sight. Not a bad price.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
02-27-2020, 03:15 PM | #5 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
I run an SMG Auxiliary pump. Couple hundred cheaper and no issues in two years...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
02-29-2020, 09:12 AM | #6 |
PM us and we can help out. Or if you already know the code you're good to go
02-29-2020, 11:30 AM | #7 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
Dont buy that over priced stuff. check out VSracing or snake eater performance.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
02-29-2020, 12:22 PM | #8 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
02-29-2020, 12:32 PM | #9 |
I have the Bosch 210's I got from VS racing for 600 bucks. I have had them for 2 years and 1 year ago I had them cleaned and flowed and they were perfect.
02-29-2020, 09:28 PM | #10 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I'd suggest using what your tuner is used to. Saving a few hundred won't do you much good if your tuner can't set up the injectors well.
02-29-2020, 10:25 PM | #11 |
