09-24-2018, 07:10 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: May 2016
Edelbrock E-Force guys, I need your help
I’ve got an old style blower on my car, been on it approx. 10,000 miles, I’ve started getting some oil around some bolts and the snout, I have a video and I will get some pictures to show what I’m talking about, but I’m wondering how/when to change the oil, and if this is something I should be worried about?
(Hard to get pictures as it’s already dusk.) Sent from my iPhone using Tapatalk
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp Last edited by LETHAL2SS; 09-24-2018 at 07:26 PM. |
09-25-2018, 04:58 AM | #2 |
MonstaBGP
I have also had the same problem, it turned out the hole was stripped somehow and wouldn't tighten. Ended up putting a hellicoil in there. So far so good. Ill keep you updated.
09-25-2018, 10:50 AM | #3 |
Which hole are you talking about exactly?
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
09-25-2018, 11:52 AM | #4 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I just looked at mine, which has 50K miles on the S/C and is perfectly clean. It was installed in Sept. of 2010.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
09-25-2018, 04:35 PM | #5 |
MonstaBGP
09-26-2018, 11:37 AM | #6 |
I had leakage between my supercharger cover and the supercharger itself. I replaced the gasket and Edelbrock gave me new longer screws. The old ones worked themselves loose.
Mine was one of the original kits as well.
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno. |
09-26-2018, 01:03 PM | #7 |
Did it make a noise as well? I believe that's whats happening with mine but it's also making a squealing noise when its under load
09-26-2018, 06:57 PM | #8 |
MonstaBGP
09-27-2018, 07:52 AM | #9 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Its a common issue. Just remove a bolt and buy some a little longer locally.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
09-27-2018, 09:30 AM | #10 |
My sound did change some as air was escaping from the supercharger lid. I do not have the part numbers, this was done probably 6 years ago. As realcanuk said just look for longer screws.
I looked in my emails and this was their response: We have added longer bolts to the lid to give better clamping in that area. We could also have him put some silicone in the dowel hole that is under that bolt to hedge against leaking. Please torque the bolts to 8 FT LBS
2010 1SS/RS LS3 M6
09-27-2018, 10:30 AM | #11 | |
Should I replace the gasket as well when I do this or did you just replace the screws? Sent from my iPhone using Tapatalk
09-27-2018, 01:45 PM | #12 |
Edelbrock sent me the gasket when they sent me the screws, so i replaced it at that time. Going on 6 years now without any issues.
2010 1SS/RS LS3 M6
10-01-2018, 09:52 AM | #13 |
any part #'s???
10-02-2018, 07:21 AM | #14 |
UPDATE: Spoke with Tony @ Edelbrock yesterday afternoon, He gave me all the info needed and is even sending me a rebuild kit free of charge even though I'm out of warranty! I'll be taking the S/C off as soon as I get the kit in and resealing the lid and servicing the fluid, I'll follow up here when I inevitably run into anything Interesting as he said most of the early built S/C were not tapped for the longer bolts.
