06-14-2018, 08:37 AM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Spark Blowout?
So on E-85 occasionally I get the motor falling on its face about 4k RPM, right as I am getting into high boost. Motor shakes and sputters I think I am getting spark blowout. Gap is set at .035 boost is around 15lbs, does the sputtering and shaking while falling on its face sound like spark blowout?
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
06-14-2018, 08:56 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
At 15lbs im at. 022 to. 025 gap
Sent from my SM-N950U using Tapatalk |
06-14-2018, 09:12 AM | #3 |
Yeah I did break in and tune on .035 put about 1300 miles on the car and just this last week started sputtering and falling on its face over 4k rpm when not completely warmed up and even after.
06-14-2018, 09:14 AM | #4 |
Too wide on the gap try. 028 1st
06-14-2018, 09:35 AM | #5 |
Drives: 2010 SS Join Date: Jun 2015
What plugs are you running? Try a non extended tip plug. Ive always ran the BR7EF for boost and nitrous.
06-14-2018, 09:49 AM | #6 |
Br7ef, but i believe i went to a 8, i was at 20to 22psi on my maggie
06-14-2018, 10:12 AM | #7 |
NGK TR7IX 3690 7 HEAT RANGE IRIDIUM
06-14-2018, 10:34 AM | #8 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Yup.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
