03-27-2014, 07:50 AM | #1 |
Cajun Mariner
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM Join Date: Mar 2010
trunk won't open
I changed my front end to the ZL1 front, now for some reason my trunk won't open. I press the button and I hear a clickin noise but it still won't open, HELP!!!!!
'10 Camaro 2SS/RS Red Jewel VVTLS3/A6
'15Camaro Z/28 Ashen Gray |
03-27-2014, 08:21 AM | #2 |
Let's go Rangers!
Well this is a 1st (ZL1 conversion = a non working trunk).
Anyway maybe (hopefully) it's just stuck, open it manually using the trunk release in the trunk. Translation: Lower back seat, enter trunk, pull trunk release. |
03-27-2014, 08:24 AM | #3 |
Banned
Drives: Camaro Join Date: Mar 2013
There is a Cause and Effect to everything. I can see how the front bumper replacement would cause this issue.
03-27-2014, 10:49 AM | #4 |
Drives: 2011 Camaro LS Join Date: Feb 2011
please elaborate cause i don't see how changing a bumper and the trunk not opening are related
03-27-2014, 11:01 AM | #5 |
Cajun Mariner
You have to use a wiring harness for the ZL1 foglights to work separately and it goes to a fuse block, so maybe something happened there , the trunk is operated by a relay in the same fuse block that the add a fuse went in, I got the harness from gen5diy. It's the only correlation that I have because the trunk opened fine before and it opens if I use the manual emergency pull thing
03-27-2014, 11:06 AM | #6 | ||
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
But if you hear the clicking sound coming from the trunk that means it is receiving the signal and therefore is receiving an electrical current. |
03-27-2014, 11:24 AM | #7 |
Let's go Rangers!
03-27-2014, 11:33 AM | #8 |
Cajun Mariner
the relay in the fuse block in the car on the driver side of the dash, is where 1 relay is, i hear that relay click, the one in the main fuse box under the hood isn't making any sound and the trunk latch isn't doing anything, I'm gonna try to put a test meter on it and push the key fob trunk release next to see if i have electricity going there
03-27-2014, 11:59 AM | #9 |
Cajun Mariner
I got it to work, I took the add a fuse out and I put the fuse straight into the fuse box, like normal and it worked fine, so I have to find out if I have a problem with the add a fuse or something else, thanx everybody
