07-21-2014, 03:39 AM | #1 |
Downshifting at red light
So earlier yesterday I was out riding around and I saw a red light and as usual I downshifted with the paddle shifters to hear the engine rev as I came to a stop . I got to first gear and before I came to a complete stop the light turned green and I hit the gas and whoa I felt the power finally my ss rocked my head like a rag doll and gave me whip lash . For the past week or two since I had my camaro I was like my v6 could take my ss but now I know the truth .my ss does not seem so fast when starting out in first gear from a stop and flooring it but if I'm in first and coming to a stop and floor it I feel the power so much more . I don't know if it is just me but when I start from first from a stop it still feels like my v6 until I get in the upper rpm range
07-21-2014, 04:21 AM | #2 |
Drives: Hyper Blue 2SS Join Date: Jun 2013
this must be your first v8... you have some learning to do
07-21-2014, 04:55 AM | #3 |
07-21-2014, 05:40 AM | #4 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
07-21-2014, 06:42 AM | #5 | |
I have experienced this as well and I THINK the following explains it. I also checked the owner's manual (Tap Shift section) and interpreted what it said as this: There is something about tap shift (or Manual Mode) on V8s, that causes the transmission to automatically shift into 2nd when you come to a complete stop. I'm not positive, but I think you then have to "manually" tap it into 1st or when you hit the gas (from a stand still) you will actually be in 2nd gear... not 1st. Since you "manually" downshifted with the taps and never actually came to a full stop the car stayed in 1st, giving you that extra jolt when you hit the gas at a slow roll. **Anyone who knows for sure - please correct me if I'm wrong**
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
07-21-2014, 08:37 AM | #6 | |
Drives: 2011 SIM 2SS/RS Vert Join Date: Jul 2011
You can tap shift down to first while in "D", and the car will revert to normal automatic mode within a few seconds. Additionally, tap shifts may be prevented from executing if the RPMs are not appropriate. I drive in "M" mode, but rarely use the tap shifts. I have found that if you accelerate somewhat aggressively, but lift off the accelerator abruptly, the car will frequently not "settle" on a gear and upshift but will remain in the lower gear and produce sharp acceleration and torque again immediately... even when coming back into the throttle gently. This can be both disconcerting ... and fun, but be careful! |
07-21-2014, 08:47 AM | #7 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
A bit off topic, but I get conflicting reports. OP says eh uses the tap shift to hear the engine rev as he comes to the light. That tells me that there is no rev matching involved with the tap shift feature. Other times I have asked this and felt that I was being told there is. Can someone answer this that knows?
07-21-2014, 08:51 AM | #8 | |
This does not mean that it will be a smooth shift, and can cause a huge jump in RPMs if you quickly tap shift down multiple gears. |
07-21-2014, 08:52 AM | #9 | |
In trying to answer OP's question, I went to the Owner's Manual and found this info: "When coasting to a stop in Tap Shift Mode, the V6 transmission will automatically downshift to 1 (First) gear, and the V8 transmission will automatically downshift to 2 (Second) gear. A 1 (First) gear start can be selected using the Tap Shift controls on V8 models." This leads me to presume that OP physically downshifted all the way to 1st gear with the Taps but since he did not come to a full stop (as he usually does), he was still in 1st gear when he hit the gas. Normally, he would have been in 2nd... hence his surprise at the increased power. I will confirm later, but I believe if you tap all the way down to 1st gear while approaching a stop and then stop for a few seconds you will see the gear indicator on the DIC change from 1 to 2, making your take-off gear 2 instead of the expected 1. I hope that makes sense and I will confirm shortly - roads almost dry.
07-21-2014, 08:56 AM | #10 |
Yeah, I know ya do and was just trying to be a more complete response for the OP and others reading. In fact, I almost put a disclaimer on my post (and now thinking I really should have) letting ya know that part of my reply was not directed toward you!
07-21-2014, 09:01 AM | #11 |
No problem, but you quoted me so I "assumed" you were replying to me (only). Thanks.
07-21-2014, 09:48 AM | #12 | |
In Manual Mode, if you tap shift through the gears while accelerating but then allow the transmission to downshift itself when approaching a stop, it will only go down to "M2" on the DIC. Therefore, if that is the norm for OP, he's used to taking off in 2nd when in Tap Shift mode. When downshifting with the taps all the way down to 1st, the transmission will hold 1st (even if you completely stop) until you tap up. I suspect OP does not normally tap all the way down to 1st, hence his surprise when the car jolted him upon acceleration. Sorry for my confusion. Hope this clears it up.
07-21-2014, 01:09 PM | #13 |
Drives: 2010 Camaro 2SS/RS IOM L99 Join Date: Jun 2013
I avoid using the Tap because i get confused during a turn lol.
-RotoFab CAI
-Kooks LTH -Ported TB -SLP Loudmouth I Muffler Delete -V8 Only Range Device -Technostalgia Advanced Taillights -Elite Engineering Catch Can -Anvil Notch Spoiler |
07-21-2014, 02:26 PM | #14 |
Yup a V-8 would do that to you.
