06-08-2024, 10:47 AM | #1 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Ltft questions for you tuner guys.
Any reason why the fuel trims would be this high and so different from bank1 and bank2? This was at hot idle.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
06-08-2024, 11:13 AM | #2 |
I should mention this is on E72
06-10-2024, 05:26 AM | #3 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I'm pretty sure the banks should be pretty close together. Do you possibly have an exhaust leak?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
06-10-2024, 04:05 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I've also had O2 sensors fail and give weird readings
06-10-2024, 04:18 PM | #5 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Vaccuum leak or a miss will make it read lean.
Does this have a flex fuel sensor or has it been tuned for E72? What do the short term trims look like and do they get better or worse at idle? |
06-10-2024, 05:50 PM | #6 |
Any codes?
06-10-2024, 06:57 PM | #7 |
No codes. I have a flex sensors. My shot term trims while driving are -3 to -4 bounced around. I can’t find any vacuum leaks either. Yesterday i had it out and noticed bank 1 would go all the way to +31 on the long term.
06-10-2024, 07:19 PM | #8 |
Swap the sensors and see if it follows to the other bank.
06-10-2024, 07:29 PM | #9 |
I'll give that a go and see what happens. I don't have one of those fancy lifts like you Mark. working on my back suck, I'm too old for that shit.
06-10-2024, 07:34 PM | #10 | |
My hernia doesn’t let me crawl too much so I had to have a lift otherwise no fun. It’s worth it.
06-10-2024, 07:52 PM | #11 |
when i get some free time ill swap the o2 and see what happens. what do you guys recommend for a replacement delfi, bosch, or nkg sensor?
06-10-2024, 08:54 PM | #12 |
AC Delco
06-10-2024, 09:46 PM | #13 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
06-10-2024, 10:35 PM | #14 |
Not sure if it would matter, but I'd use the same brand that you currently have just in case there might be a difference in others that would affect your tune.
Thread Tools | |
