Old 03-17-2011, 11:10 AM   #1
Zorlander69
Drives: 2010 Camaro LT
halos
I'm the proud owner of a new 2010 camaro and I have question about projection headlights. Hope I've come to the right place....
question: is it posible to install projection {with halos} headlamps on a non RS vehicle and what is the proceedure?
any info would be greatly appreciated!
Zorlander69 is offline   Reply With Quote
Old 03-17-2011, 11:11 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here is a start for you.
http://www.camaro5.com/forums/showthread.php?t=120440
You can also replace your headlights with the OEM RS headlights or a good handfull of people use Eagle Eyes with HID bulbs.
Build Journal
Old 03-17-2011, 11:15 AM   #3
Zorlander69
thank you!
Old 03-17-2011, 11:42 AM   #4
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
Yes it can be done. I've done it. Real easy to do. All you need are HID headlight assemblies and you'll need the ottobody wiring harness. And the ability to remove your front bumper. (which is easy too). I replace mine in about an hour by myself. That includes removing and reinstalling the bumper.
Good Luck....
Bone
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
New Headlight and Tailight LED Halos!!!! Wes@Flashtech Exterior Parts & Accessories 23 12-16-2010 09:40 AM
Group Buy!!! LED Headlight and Tail Light HALOS, Only $99 Each!!! Wes@Flashtech Exterior Parts & Accessories 51 09-27-2010 08:19 PM
Help w/ toggle switch for Halo's erk5000 Cosmetics and Lighting Modification Discussions 0 09-14-2010 01:06 PM
Those WITHOUT the Halos? caverman 5th Gen Camaro SS LS LT General Discussions 43 08-27-2009 03:32 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
