06-14-2018, 09:27 AM | #1 |
Car Enthusiast
Drives: 2010 Rally Yellow Camaro 2SS A/T Join Date: Dec 2010
L99 Replacing thermostat
Anyone have instructions, links or video on how to replace the thermostat on a L99? Also having hard time finding the torque for the thermostat housing bolts
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016 |
06-14-2018, 09:33 AM | #2 |
Drives: 2017 Silverado Join Date: Mar 2017
I can't help you with the torque for the bolts.
1. drain the coolant at radiator bottom drivers side has a valve. when done close valve. 2. unbolt thermostat housing. 3.swap thermostat 4. bolt housing back to water pump 5. fill with coolant and burp it. probably the longest step. really nice to have a large funnel for this step. Did I miss anything?
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis |
06-14-2018, 10:03 AM | #3 | |
Car Enthusiast
06-14-2018, 01:38 PM | #4 |
no but you will still lose enough coolant that you will still need to fill it.
06-14-2018, 03:27 PM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
Torque is 11 ft/lbs or 132 inch pounds
06-14-2018, 04:01 PM | #6 |
'It's an experiment'
Can I ask why you’re changing it? They are pretty resilient. Do you have mods that are causing a heating issue while driving?
-Don
747 RWHP 794 RWTQ
06-14-2018, 10:07 PM | #7 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
fill the engine from the top hose! do no fill the radiator first because if you do you will spend a few days getting air bubbles out of the cooling system
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-14-2018, 10:43 PM | #8 |
Drives: 2011 camaro 2SS Join Date: Apr 2017
I still cant get my bubbles out
06-15-2018, 06:26 AM | #9 |
Drives: 2011 ss Join Date: Sep 2015
Get a radiator funnel. I picked mine up after hanging out with my mechanic buddy years back.
No regrets |
06-15-2018, 07:52 AM | #10 |
Car Enthusiast
Vehicle seems to be overheating the first 15 minutes. Fans are on so thinking its the thermostat.
06-15-2018, 08:13 AM | #11 | |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
See this L99 thermostat replacement video below. Or you can find it from the link in my signature also. To help get the air out, fill the coolant from the top hoses and squeeze the bottom hose with the cap off to move trapped air out.
