03-02-2018, 12:50 AM | #1 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
aem boost contoller, not controlling lol
so I had a shop install the controller, set it at 10 and 14 psi, worked fine for about a week, then nope...now I have INFINITE boost lol. even with the controller off, its still over boosting. the shop cant get me in for weeks, what should I be looking at for whats wrong??n infinite boost make engine go boom if I am not careful!
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
03-02-2018, 01:31 AM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
Usually the wires going to the solenoid get damaged.
03-02-2018, 04:53 AM | #3 |
Drives: 2011 Join Date: Sep 2017
Mine just stopped working too.Have to figure it out aswell
03-02-2018, 08:36 AM | #4 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Also, check the boost reference lines into the wastegates. If they pop off then overboost will occur.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-02-2018, 01:29 PM | #5 |
Drives: it changes Join Date: Nov 2010
Based on your description...it sounds like a pipe has come off the wastegate.
Although that should never be able to happen as naturally they'd all be secured properly and use good quality pipe.... |
03-02-2018, 02:54 PM | #6 |
Like so...
03-02-2018, 02:56 PM | #7 |
Exactly how it should not be lol.
03-02-2018, 04:57 PM | #8 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
I would agree with Kevin, this seems more electrical. I think if you just had a line off the wastegate it would resort to spring pressure. Having infinite boost tell me the controller solenoid is locked open somehow and you are at 100% duty cycle.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-02-2018, 05:10 PM | #9 |
Nope. Losing a boost reference line will resort in max turbo boost. Been there, done that, fastened "correctly" now. Not going there again.
03-02-2018, 05:20 PM | #10 |
There is almost nothing electrical that will give the symptoms he is describing.
The most obvious place to look is as per above. |
03-02-2018, 06:05 PM | #11 |
thank you for the advice, and particularly the pic! I didn't install it so wouldn't be sure what to look for. guess its time to crawl under there.
03-02-2018, 08:06 PM | #12 |
Oh right. Anything bad in the solenoid would result in spring pressure. Overboosting is a bottom line or diaphragm problem. A little hole in a diaphragm can cost you thousands guys. Be careful
03-03-2018, 02:36 PM | #13 | |
duh me, I wasnt thinking right.
