04-24-2018, 07:23 PM | #1 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
how to tell stock valve springs from aftermarket
is there any way to identify stock valve springs from an aftermarket set?
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
04-25-2018, 12:34 AM | #2 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
Best thing to do is take a spring to an engine builder and have it checked out, he will measure the P.S.I. both seat pressure and open, takes a few seconds.
04-25-2018, 12:50 AM | #3 |
well it'll be at a engine builder, that's the issue...so what are the stock spring measurements for those?
04-25-2018, 08:33 AM | #4 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
stock springs are blue or yellow so it should be easy to tell what is stock vs aftermarket
ls3 spring specs: From the GMPP catalog 12586484 Valve Springs (not shown) • Beehive style springs • Standard LS6/LS3 springs • Use cap P/N 10166344 • 1.250" @ 295 lbs. pressure • 1.800" installed height • Max lift .570" @ 90 lbs. pressure
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-25-2018, 10:47 AM | #5 |
So just looking at them the stock springs are blue or yellow? The whole spring? You're sure?
04-25-2018, 11:02 AM | #6 | |
there is no difference between the yellow or blue springs aside from the color of the coating/paint google it if you are still unsure
2010 2SS/RS
04-26-2018, 10:26 PM | #7 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
+1 This and whatever color the valve spring is.
Mr. Clean
04-26-2018, 11:45 PM | #8 |
'It's an experiment'
These are the stock bee-hive springs (not dual springs):
New they may have been blue or yellow but, not with miles ;o) Aftermarket depends on brand. These are BTR dual spring .660 with titanium retainers: GMPP (Chevy): Bee-hive next to a dual spring: Some aftermarket springs can be a bee-hive design, thus it depends... Hope that helps... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 04-26-2018 at 11:57 PM. |
