04-25-2017, 07:47 PM | #1 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Line lock mock up/install
So, I got tired of waiting on a company to come out with an easy kit to do a line lock for our cars. Unfortunately the only solution that I've found is one very similar to the newer mustangs. Our cars have a European style ABS system. Meaning each line out of the master to the ABS block controls a front and rear wheel. You can no longer just put a solenoid between the master and the ABS block and go. We now require two solenoids, one for each front wheel. That jumps the cost significantly. I'm going the "easy" way out. I have seen photos of both solenoids right after the ABS block, but it's a bit cramped for my liking. I'm going right at the junction of the hard line and the rubber hose. This will allow me to upgrade to braided lines when I get the extra funds. So far I'm into this venture for about $200 just in a pair of B&M solenoids and the fittings to adapt it.
Stock junction
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
04-25-2017, 07:48 PM | #2 |
Planned location of the solenoid.
04-25-2017, 07:52 PM | #3 |
Drives: 16 Red Hot 2SS Join Date: Oct 2016
Interesting.subscribed for updates.
'16 Red Hot 2SS A8 sunroof
04-26-2017, 06:26 PM | #4 |
Minor set back today. The fittings I ordered are not right....that's what I get for guessing. Worst part is it seems the ends are a weird size. So after about 2 hours of running back and forth between parts stores, I'm no closer to fitting these.
04-27-2017, 06:31 PM | #5 |
Finally got it situated in a position I like. Plenty of room, once I got out of my own way. It'll even hide behind the inner wheel well. Now to button everything up, and duplicate it for the driver side.
04-28-2017, 06:15 PM | #6 |
The only evidence that there is a line lock hiding under there.....
04-29-2017, 11:33 AM | #7 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
very nice, might have to copy it.
04-29-2017, 09:08 PM | #8 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Good stuff. I knew the 5th gen had kits for it. Good to see a diy for the 6th.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
04-29-2017, 09:33 PM | #9 |
Drives: 2016 2SS Join Date: Nov 2011
That is pretty slick, thanks!
Who Dares...Wins |
07-26-2017, 06:08 PM | #10 |
Drives: 2016 Camaro SS Join Date: Jul 2014
Very tricky installation! Nice work.
07-27-2017, 07:14 AM | #11 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Glad I saw this, sub'd as well
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
07-27-2017, 07:28 AM | #12 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Has anyone looked at how the ZL1s LL is configured and if it can retrofitted to an SS?
07-27-2017, 08:36 AM | #13 |
FMPG
Is it even available to purchase independently? I think some of the model specific parts are limited supply for a while, like the short throw.
07-27-2017, 09:15 AM | #14 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
I believe trying to retrofit LL from the ZL1 would be difficult considering there are electronics involved. It appears with this setup, it avoids all that.
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
