09-17-2016, 10:14 AM | #1 |
LawBraker
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue Join Date: Oct 2008
Water spots on Rims
What's good to remove water spots on chrome? I have some Lexanis that I want to clean up and put them on my 2016.
09-17-2016, 10:20 AM | #2 |
09-17-2016, 10:27 AM | #3 |
Drives: '13 Roush S3 '16 Ram Sport 4X4 Join Date: Apr 2009
This will probably be the best stuff to do the job. Safe for any surface.
If you're not familiar with CarPros,....get familiar with them. They have a killer product line. I have the Cquartz Finest applied to my '16 Ram Sport 4X4 regular cab and it's amazing. Good luck! http://www.autogeek.net/carpro-spotl...t-remover.html |
09-17-2016, 10:44 AM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Any metal polish will do it, get a mothers ball for your drill - the hand cannot move at 500 rpm....
09-17-2016, 10:53 AM | #5 | |
davet
Drives: 2016 2SS Mosaic Black Join Date: Apr 2010
For strictly water spots this stuff is great.
Replacement car ordered 2/02/2016
2/03/16 2500 2/04/16 3000 no TPW 2/8/16 3000 TPW 2/29 2/18/16 3400 3/3/16 3800 3/4/16 4B00 3/5/16 4300 3/7/16 4200!!! |
09-17-2016, 12:02 PM | #6 |
Drives: 2017 Camaro SS Join Date: Jun 2016
Would anyone advise using a diluted CLR mixture to get rid of them? I have used it many times on painted and chrome surfaces and never had any problems. Just a thought.
09-18-2016, 07:54 PM | #7 |
Drives: 50 ann. Rs, V6, sunroof, nav, spl Join Date: Aug 2016
Location: Rochester NY way upstate 3 hours from Toronto on Lake Ontario
White vinegar should do the job
09-19-2016, 08:14 AM | #8 |
Drives: 2016 Mosaic Black 2SS Join Date: Dec 2013
09-19-2016, 08:40 AM | #9 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I don't use anything at all. I just wash them with a micro fiber glove and just wipe mine down with a drying cloth and don't get any spots.
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
09-19-2016, 08:44 AM | #10 |
Water spots come in 2 types, chemical and mineral. CLR and vinegar will work fine for the mineral spots, however chemical usually has to be polished off. And then there's the problem of whether the water spot has actually etched itself into the finish. And that will require polishing, definitely. Start with Meguires 205 and As said above, a machine polisher, If that doesn't get it start with Meguires 105. A mothers Powerball on a cordless drill should make short work of it.
As usual, my friend Mike Phillips at autogeek nails it: http://www.autogeek.net/how-to-clean-alloy-wheels.html |
09-19-2016, 09:05 AM | #11 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Coke, the phosphoric acid in coke, is a very mild (less than vinegar) acid to clean chrome. Plus it tastes better than vinegar
09-19-2016, 09:26 AM | #12 |
Drives: 2018 Camaro ZL1 Join Date: Jul 2016
Best and cheapest thing to use is Brasso!!
Guys in the Forces have been using this for decades! Best for Brass, Chrome, Stainless Steel, and Aluminum! Wipe on, let it Haze up, Wipe off... That easy! Great stuff!! This is what I use on my exhuast tips! I had a 2005 Sierra GMC and the bumper had a few rust spots! Took the rust off and never had rust again using this product! Used to use it on my Aluminum rims On my longnose Peterbilt as well! Cost about 5 or 6 dollars!! |
