10-09-2018, 12:00 AM | #1 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
2017 Camaro 1LE Whipple
I'm looking to buy a Whipple and supporting mods for my 2017 Camaro 1LE next month. I'm just trying to piece everything together right now so I know what to buy. I think I have everything down but just want to confirm; Whipple, headers, LT4 injectors and the ZL1 high pressure fuel pump.
Is there one dealer who would have everything I need? Thank you!
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
10-09-2018, 06:08 AM | #2 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
I got most of my stuff thru WeaponX and Jannetty.
You will also want LS crank seal GM part # 12585673, and sparks plugs, I used NKG-6509, 3 bottles of water wetter. It would be good to also install a gauge to monitor IAT's and boost, i used a P3 gauge with analog boost and am happy with it. Good luck with your build!
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
10-09-2018, 06:41 AM | #3 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Not going to consider the Maggie?
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
10-09-2018, 07:55 AM | #4 |
Drives: 18 2SS 1LE Join Date: Jul 2018
10-09-2018, 07:56 AM | #5 | |
Damian559 we are your one stop shop for supercharger performance. We are an authorized Whipple dealer and we also have the LT4 fuel pump and injectors for sale as well. Long Tubes? We have tons of options and very aggressive pricing. Also, use code CAMARO6 and get your forum discount. You can save on our already low prices. If you're local to us we also handle installs and tuning. |
10-09-2018, 08:32 AM | #6 |
Its added to the GM approved coolant. Also whipple recommends using it right in their instructions.
10-09-2018, 09:03 AM | #7 | |
Ted.
www.jannettyracing.com
10-09-2018, 09:36 AM | #8 | |
Cheers, Kayla L. 801.545.4215 |
10-09-2018, 03:58 PM | #9 | |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
10-10-2018, 01:14 AM | #10 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
10-10-2018, 05:54 AM | #11 |
Yes. I know. The ZL1 in tank pump gets overrun and you will either want to add a voltage booster or an auxiliary fuel system. Probably depends on your HP goals.
To add more color, with e85 we saw the zl1 in-tank pump dropping pressure at 8psi. Once we installed the BAP, the low side stays rock solid with e85 and 12 psi (760whp). In fact, I expect that we can run up to about 850whp with the zl1+BAP pretty easily (will be about 3-4% higher on manual). With e85 (really e70), we are pretty close to the injector pulse width limitation on 12psi (no alky or race fuel). I suspect with race fuel we could easily run to 830-850whp. As we start upping the boost, however, we could start seeing heat issues and need to add alky...I am not quite there yet so will defer to others who know for sure. I would recommend calling Ted and just talking through the options. He has taken the time with me to make sure I had everything and even special calls when I was on the dyno to tweak in real time.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 10-10-2018 at 06:23 AM. |
10-10-2018, 06:55 AM | #12 |
Once again this just my two cents and it's worth exactly what you've paid me for this advice, but water wetter is basically like snake oil, especially if you're going to run coolant instead of straight water. The ASTM corrosion standards that they meet are also significantly less than what would typically be required of engine coolant. If Whipple calls it out in their instructions, that certainly is a head scratcher.
10-10-2018, 08:47 AM | #13 |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
Yup they call for it.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
10-10-2018, 08:54 AM | #14 |
Thread Tools | |
