07-23-2013, 04:40 PM | #1 |
Drives: 2013 Camaro LS m6 Join Date: Jun 2012
200 pound weight loss?
So I'm thinking about stripping my car of some weight but before I drop to much money I gotta ask, how much would my performance be affected by losing around 200 pounds?
07-23-2013, 04:45 PM | #2 |
knows 2 facts about ducks
It'd increase by a bit. 100 pounds equals (roughly) a tenth in the quarter mile.
07-23-2013, 04:55 PM | #3 |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
I dropped about 120 pounds last year.
She said "this car is your girlfriend now", and I agreed, we were both right. I didn't notice any increase in speed, but it sure is more quiet on the inside than it ever used to be....
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
07-23-2013, 05:03 PM | #4 |
Drives: 2013 Camaro 2LS Join Date: May 2013
07-23-2013, 05:15 PM | #5 |
Drives: 2019 SS 1LE Garnet Red Tintcoat Join Date: Jun 2013
One of the best comments I've ever read...
07-23-2013, 05:24 PM | #6 | |
Drives: 2013 AGM 1LE/2SS/RS Join Date: Mar 2013
I've had that same quote thrown at me.. you did what I could not.. my hat is off |
07-23-2013, 05:33 PM | #7 | |
Drives: Camaro Lighting Experts Join Date: Feb 2012
Nick C.
07-23-2013, 05:36 PM | #8 |
Drives: 2010 CAMARO 2SS/RS WHITE Join Date: Jan 2011
YOU THE MAN!
07-23-2013, 05:44 PM | #9 |
07-23-2013, 06:09 PM | #10 | |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
There's an old saying: people shop HP but buy torque. Personally I feel that with the stock rear end ratio and the high weight, the SS could use another 50 ft/lbs starting at around 2500 rpm, and then the car would feel a whole lot different
07-23-2013, 10:44 PM | #11 |
What parts of the car would you consider stripping, or getting aftermarket parts for to eliminate weight?
07-23-2013, 10:49 PM | #12 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Forged wheels and an aftermarket exhaust and lightweight battery would easily drop 100lbs off the car. The stock mufflers alone are like having lead weights tied to your ankles.
Ps. The washer fluid tank seemingly holds about 800 gallons of fluid so that has to friggin weigh a ton. 2 1/2 damn years and mine still has some original fluid in it and i use it a fair amount. Personally i think a fluid fairy comes and refills it in the night. |
07-23-2013, 10:51 PM | #13 | |
Drives: 1ss in Blue Ray Metallic Join Date: May 2013
Also at the 120lbs of weight savings comment.
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
07-23-2013, 11:15 PM | #14 |
TREMEC6060 1-2 needs fix
Drives: 2011 2SS/RS Join Date: Jul 2011
Lets say your car weighs 4100 pounds. 200 pounds is about 4.78 percent. Losing that much weight will also theoretically reduce your 1/4 mile time by 4.78 percent. Same thing with 60' time, trap speed, and average lap speed. Also about 4.78 percent increase in LBS/HP ratio and 4.78 percent reduction in 60-0 brake distance.
Just kidding, sounds logical, but reality has a lot of variables and I really wouldn't know how to make a general prediction. But there must be tables out there of weight reduction gains with all else being equal for drag strip times and so on. It's probably not a linear thing and the formula will be complicated. Use this link to simplify your calculations. http://www.wallaceracing.com/Calculators.htm They probably have formulas that will proved a better approximation than I could ever figure out.
Asimov's Fourth Law of Robotics: If you don't know what else to do, wave your arms and run around in circles.
