Old 10-22-2020, 05:27 PM   #1
MichaelOrtiz949
Drives: 2012 Camaro 2LT/RS
Tire Sizing Help!!
Hi guys!! Excuse my ignorance I am horrible with sizing.. but I recently purchased a set of HRE FF04 wheels for my 2012 Camaro 2LT/RS. The sizes are 20x10 for the front two and 20x11 for the back two. What's the largest tire size I can get away with to fit my car? Site says 285/30R20 and 305/30R20 but I thought that would be too big? Customer Service isn't as helpful as I'd like either. Thank you!
MichaelOrtiz949 is offline   Reply With Quote
Old 10-22-2020, 08:51 PM   #2
judkins75
Silver Shark
judkins75's Avatar
Drives: 2014 2SS GM Npp 6 speed manual
You'll be fine! I have the same wheel and tire set up. No rubbing issues at all, plus it makes the car look more bad ass with those big tires sticking out back..
Silver Shark20*10,20*11 Z28 black gloss replica wheels, 285/305 tires, BMR Strut brace,Kooks lt headers/hfc, CAI cold air intake/air scoop
judkins75 is offline   Reply With Quote
Old 10-22-2020, 11:51 PM   #3
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
Mine has F 275/40r20 on a 20x10 and R 315/35r20 on 20x11. No issues whatsoever. I'm running the MRR M017 (6gen 1LE rims).
You should be able to run ZL1 size tires without issue which is F 285/35r20, R 305/35r20 and their oem offsets.
jcampos is offline   Reply With Quote
Old 10-23-2020, 07:43 AM   #4
hudson773
hudson773's Avatar
Drives: 2014 camaro SS
those are the sizes I went with, stock size for ZL1. I also chose "all weather" tires, much better than the summer pirelli "skates" where I live. unfortunately this is the ONLY manufacturer who makes all weather in those sizes. no clearance issues at all.
hudson773 is offline   Reply With Quote
Old 10-31-2020, 12:29 PM   #5
Jayscanvas
Drives: 2010 ss
Yes I also run 315/35r20 on my rears nonissue
Jayscanvas is offline   Reply With Quote
Old 10-31-2020, 12:44 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
I have heard of some people having to tie their parking brake cable back when running 315's, but it doesn't look like it happens to everyone. I wonder if it's a model year thing.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels - Tuned by Ryan @ GPI via HP Tuners
Old 11-01-2020, 10:09 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I am running 275/35/20 front's 20x10 and 315/35/20 rear's 20x11. I did have 335/30/20's on the rear for a while with no clearance issues at all, and I'm lowered 1.25 all 4 corners.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
