Old 07-05-2018, 10:47 AM   #1
Yellow Bullet
Yellow Bullet's Avatar
Drives: 2015 Camaro SIM LS3
Brake cooling ducts and intake scoop
Anybody craft their own intake scoop AND brake ducts? If so where? Could fog lights be modified to be the brake cooling ducts and the intake scoop in the grille?
Derrian
2015 Camaro 1SS/RS LS3 SIM
~NPP, more to come~
Yellow Bullet is offline   Reply With Quote
Old 07-05-2018, 01:10 PM   #2
Rahnok
Fish Poop Aficionado
Rahnok's Avatar
Drives: 2015 2LS SIM
I have also been thinking of using the fog light holes as brake ducts. I’ll be working on something when I get access to a 3D printer at UGA next month. I’d be interested to see if anyone else has already done this.
Rahnok is offline   Reply With Quote
Old 07-06-2018, 10:20 AM   #3
elegalR1der
elegalR1der's Avatar
Drives: '11 LS3
Z28 brake cooling ducts
https://www.gmpartscenter.net/oem-pa...ducts-23252398
elegalR1der is offline   Reply With Quote
Old 07-06-2018, 10:33 AM   #4
elegalR1der
Drives: '11 LS3
Here's one you can DIY
http://www.sccaforums.com/forums/aft/448191
Old 07-06-2018, 11:08 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Theres a reason you shouldnt run them from fog light holes something about clean vs dirty air coming in through them, best to run them from under the car or outer lower grill section.
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
